Side panel delamination on XLII models
Archived replied 11 years, 7 months ago 50 Members · 170 Replies
Procrastination will never let you appreciate your Prevost while it depreciates.
Now now boys you all know I was in charge of the water sourse at the convention center, and my only comment is NO COMMENT it worked on all most every body. BUT I made Rita drink almost two gallons, had the perfect bus there and still driveing the old 97 rainbow so the Water was not the only factor, Thanks Yall, Me
Update
Last week I had an appointment at Prevost JAX. I arrived the day before my appointment. Cindy the branch manager and John met us when we pulled in. As usual great Prevost hospitality, plenty of room and as best as can be expected at a repair facility. The sites were easily accessible. I figured that I would make the day worth it so I had a Level 3 service done as well as the Panel/leak evaluation. It was determined that we need the whole magilla…rivet the panels and cover the repair with stainless covers. I saw one completed and if you weren’t looking for it you wouldn’t know it was done. At the same time while I was there I saw a bus that was in the middle of the repair. All the riveting and sealing was done but the finishing strips were not installed. They pressurized the coach and sprayed the seams with soapy water, it was amazing as they found 2 small leaks which I would assume they repaired. The next day they started the installation of the finishing strips and I was pretty impressed with the process and the professionalism in completing it. So at this time everything regarding my coach is in Canada awaiting the decision of what Prevost’s responsibility will be. From my prospective I think its pretty cut and dry. My coach is an ’07 with 47k miles and has had a history of panel problems. Hopefully I can get a quick resolution to the problem. -
Update:
We were at Prevost yesterday and as I suspected, my coach needs the entire process done. They started looking and almost every seam was loose and that includes bay doors, slide room panels and the passenger side panels too.
They pried on them with a plastic tool, took some pictures, and said it would be a couple of days before they got the answer back from Prevost corporate about what would be covered. They were not surprised by the findings on my bus. It was almost as if they knew it was going to require everything.
We discussed the leaking issues, and John is really sold on this new way to fix things. He thinks it will be a final fix, something they have not had in prior attempts. I think they are still tweaking the process, but it remains close to what has been posted before.
I got the chance to see one repair in progress. It is a very labor intensive procedure, but from the explanation and seeing it in person, looks like it should fix the problem. They had a 2007 that just had returned from being painted that looked fantastic. The paint blending was great and the coach looked like new.
I will post again when I get my answer back from Prevost.
Glad you folks are getting the coaches repaired. I have one of the old riveted models. Wife and I thought about trading up as the prices are looking better all the time. Our bus is original inside with electric devices all replaced but everything else 1992 style. When did the problems start with some on the coaches. I would be beside myself on this problem. The little things raise my blood pressure. Haven’t researched much on the issue. Hope everything goes well. Keep us posted.
glen
Thanks a bunch Rick and Mark, it really helps to here how things are handled with the delam issue and the more information we accumulate will help others get through the process.
Keep it coming…
Glen,
The coaches affected appear to be limited to XLII chassis only. And we have no way of knowing if the problem is widespread or is limited to a small percentage of the fleet.
I got word from Prevost that they are covering the entire repair including paint. I have an appointment for June 3rd to drop it off! I had a good conversation with John in service, and it looks like 4 to 6 weeks for the entire job is still about how long it will take. I hate to be without the bus this time of year, but I want to get it finished so I will live with it.
If you have not had yours inspected, you should consider getting it done as I would think that lead times are only going to stretch out as time goes on….
Great news Mark, you’ll finally get it done with rivets and no more worry. Mine is the one ahead of yours, I go in next week, the 2nd of May and same deal, about 4 weeks at Prevost.
Now you don’t have to worry, they’ll practice on mine!:)
Like Mark said, you folks with XLII’s need to get your inspection and get the ball rolling.
I think Rick takes his in the week before mine as well. They will have to start speeding up or they are going to have a backlog…
I’m in Memorial Day but I’m dropping her off the week before to beat the holiday rush. Prevost didn’t disappoint me by coming to the party and taking care of the repair as well as a “lions share” of the paint work. After observing the repair I think its the only way to go if your coach has the problem.
Good to hear that Rick, when you drop your’s off, check on mine please! You can’t miss it, being a Liberty the rivets are gold plated and the vertical covers will have a hint of gold on the edges. Be sure to check my slides out.
I must have missed the part of the repair where non-slide coaches get slides installed….
Sorry, all the content of my post dissapeared so I’m trying to update it now. I just joined this forum and am about to purchase my first prevost. I’ll list out the specs so when you respond you will know what it is that I’m buying. It is a 2001 featherlite vantaire 45′ hwh,auqua hot,4 roof airs, 17.5 powertech,2x 4k trace. I read this thread about the delam issue and called the dealer and asked him about this unit and that issue. His response was that he was aware of the delam issue and had not seen it on any unit except ones with slides and did not think this one had an issue nor would it. I did not pick up in this thread about this only applying to units with slides. The issue of delam and any other know issues with plumbing,elec, mechanical, etc. are exactly what I’m tryiing to find out about so I can make an educated decsion on this purchase. I’m aware of the date codes on tires and batteries and have that accounted for.
Thank you in advance for any feedback and advice.
A buddy of mine that owns Taylor Tours in Phoenix tells me 3M is picking up some of the cost for the problem they do their own repairs for the de lam, he says some of those repairs can run into a 100,000 + dollars it’s not a safety issue so he doubts it will ever be a forced recall but is a problem for Prevost
good luck
