    July 14, 2013 at 11:49 pm
    Susan you say Portland are you speakin of Oregon? I live in Wilsonville and another PCer on this board lives in Sherwood area.
    Greg
    July 16, 2013 at 12:51 am
    Hi Greg! and hello, Sherwood member! If you get down McMinnville way, I would love to meet up.
    I go through Sherwood often, on my way to Portland. I have relatives in Multnomah. Greg, you’re in the home of Camping World. ha ha I almost stayed at the nice park in Wilsonville. But it’s a bit too urban for my cat. They won’t let him off the leash (and rightly so in that environment). Here he gets indulged. I like it here in the valley. It’s got some good restaurants and wineries. One of my favorite things so far is the annual UFO Festival Parade. They take themselves very seriously around here. http://www.youtube.com/watch?v=Z0pummh95bs
    Coming through Sherwood today, I was on my way back from Grainger, where I picked up a check valve rated to 450 degrees for only about $20…CDI brand…hope I did OK.
    I also got this pipe sealant…big tube…I am hoping this will be OK…if not, I can go to NAPA and get that blister pack that you recommended, Al. I just picked this up because I was there. (That says “ANTI-SEIZE”
    Here is the check valve:
    They said they didn’t have any compression fittings for this situation. And I walked out of NAPA the other day without compression fittings too, having asked for them but, when I got home I realized that they gave me the push-on kind. The fellow at Grainger told me about a place in Tualatin that makes custom fittings and hoses, A1 Coupling. Have you heard anything about them, Greg? Their site is a1coupling.com.
    Susan
  • Sammy
    July 16, 2013 at 7:04 am
    The check valve looks like it’s for water?
    July 16, 2013 at 7:22 am
    More importantly it looks like it has a metal to metal valve seat and it is sensitive to orientation.
    The check valve should be a spring check with a rubber or similar material for the seat, and it should be an inline with orientation in any position. If a length of copper tubing coming from the compressor is used the heat at the check valve should be minimal so the max operating temperature could be less.
  • Susan
    July 16, 2013 at 7:40 am
    My AUX air leaks down about 10 lbs a week now
    Great Job Al.
    In Texas, we would call that leak free. Another example of how dedicated effort pays off. Leak back through the aux air compressor is often a problem. I installed two check valves on the discharge line about four feet from the compressor to allow for the air to cool. The best way to keep the aux air compressor discharge air cool is to avoid having your aux compressor run all the time.
    Welcome to the leak free club (an exclusive “busted knuckles” membership club).
    My experience has been, once the coach is leak free, it will last for years. My last leak finding adventure was two years ago.
    Hector
    July 16, 2013 at 8:34 am
    I’am reading through the messages this morning and what pops up ?
    Never expected that I would hear from the from the father of the Texas Bubbler.
    Thank you…. Hector, I really appreciate your comments.
  • Roger
    July 16, 2013 at 8:47 am
    Susan,
    Ditto with Tom, the fitting in display reminds me of ones used in marine applications for liquids.
    The check valves used in pneumatic lines do not look like that.
    Sealant looks OK ….. with this application.
    July 16, 2013 at 1:33 pm
    Thanks for saving me from potential headaches with this valve…I will keep looking.
    Susan
  • Susan
    July 16, 2013 at 2:03 pm
    Hector, where did you purchase those two check valves?
    Susan
  • Fred
    July 16, 2013 at 4:29 pm
    Susan,
    Here’s DoT approved check valves. Although not really required on your Aux air system, there no reason not to use them.
    http://www.alkoncorp.com/catalog/2010-transdot-catalog-web.pdf
    July 16, 2013 at 5:51 pm
    July 17, 2013 at 7:00 am
    Al,
    Thats for your comment.
    Susan,
    I do not remember where I purchased the check valves. The catalog that Gil attached will provide choices for check valve. Mine are rubber seats (better for tight shutoff). I installed double checks and be sure to install as far away from the compressor as possible. If the aux air compressor runs often, the air will become very hot( the hot air can damage the rubber tight shutoff seat in the check valve). Very Important, manage leaks in the aux system such that suspension leaks are at a minimum to decrease aux compressor run time. Mine will run once every few days.
    I am heading to high country Colorado, so I am sure the cool weather will bring out leaks.
    Buying a bigger compressor is not the answer.
    Hector
    July 17, 2013 at 8:24 am
    Someone recommended I install a check valve near the Prevost aux air connection. This makes a lot since for multiple reasons. The compressor air will be cool and it prevents any air leaking through the compressor’s regulator, if you have one. This is not a substitude for the one your replacing but rather an augmentation.
  • Jim
    July 17, 2013 at 9:11 am
    http://www.valvecheckinc.com
    Here is a manufacture of check valves. This company made my 450 deg heat check valve.
    chart —— 6200-2mm series 1/4 inch NPT with “viton'” seal is the best sealing material available.
    Another choice you have is…..cracking pressure. The amount of air “PSI” to open valve.
    Ryan, was phone contact
    July 17, 2013 at 8:41 pm
    Hi Hector,
    Thanks so much for this advice!
    I have seen you mention twice that you installed not one but two inline check valves. That sure sounds like a great idea. I have never installed even a single one before, though, so I am wondering
    — whether you used a check valve that is designed specifically to go into a nylon air tube (or one that could have other uses) and
    — does the check valve have the dreaded push-in fitting or the compression type and
    — did you bump the up against each other (have one valve screwed into the other???) or if not, how far away did you locate one from the other?
    Thanks again, Hector!!!
    You must be in for a climb if it’s gonna be that cold in Colorado. I drove my coach home to Pagosa Springs 3 years ago. As a completely green driver, I had to go over Wolf Creek Pass (in the San Juans in SW CO). Maybe you’ve heard the song about Wolf Creek Pass, or you’ve gone around that hairpin turn? That was in November and I was worried about ice patches too. But no ice and a smooth descent. I was really glad that I already knew that pass well, though. I don’t think the signs give anything near realistic warning about that turn. Or that tunnel, for that matter.
    Susan
Page 3 of 5
