Anyone find any LED 24 volts I would like to replace the bay lights and engine lights? Could really use something brighter in those areas.
Greg,
Do Google to pick up Grote Lighting Corp factory site. They have a very good cross referance. FYI the last letter on there part number is color;
47072 the 2 is red
47073 the 3 is yellow
When you locate the lighting you want Grote system has the 24 Volt info under the 12 volt
they have a list on the product information of the colors available. If you get the Grote number you can get other mfg. like Peterson.
Hope that helps,
Darrell,
It’s jst a bulb change out, no wiring or changes needed.
Just got the lense and the gaskets yesterday the bulbs came the day before bulbs work good have to put them on just one way, will attempt to change out today before Christmas dinner, Gary, Now i am thinking about the interior lights?
Well, Christmas Morning I went to work and started changing out the cargo and the curb lights, 15 in all pretty somple just make sure to remove all of the old gaskets, took my time, about 4hrs total, the difference is amazing the new lense make the coach even look better eliminating the old yellowed ones, will try to get some photos to post, PS make sure you order extra bulbs they are not made very well and I broke 3 while installing the lights, Gary
Gary Your supposed to have hold off on the drinks until after the installations! No drinks= no broken bulbs. Rick
Rick, I did hold off, well except that wee dram I put in my coffee, Gary
Here’s what the finished project looks like. At night time, the difference is amazing.
Faded lens vs new
Old faded lens
New lens with LED
Tom I can’t find the lens or the bulbs on the suppliers web site. I am must be navigating in the wrong direction? Rick
Hello Tom, Will these gaskets and lenses fit our original Marathon 2000 side lights? Looks like the lens is a bit smaller, please advise. Thanks
Two Slide Tom, I did the same thing you are doing but the gaskets I got will not work because the material is too thin to take out the curve in the lights housing. Those from LMC Truck were on 85 86 or 87 pickup trucks where the cab lights for the cargo area were.
The new lenses really look good just wish I could find gaskets thick enough to work on the light housings.
The festoon bulbs just don’t have enough leds on them to be bright enough.
I know you have been through this but I just spelled it out so others would know what we were talking about.
I hope you like your new name I gave you, Jon’s is going to be “Crestron Jon”
Buddy,
Apparently you did not read PC rule 121.A, subsection 2.11 which states you don’t pull on Superman’s cape, spit into the wind, pull the mask off the Lone Ranger or pick on Tom and Jon.
Can I do all those things if I get a Liberty or a Marathon and getd rid of that SOB !!!!!!!!!!!!!!
Tom I really am intrested in the gaskets. Let me know how they do.
I have been thinking of trying to find a company that can make what we need because there are a lot of coaches out there with those lights on them.
The uglest part of mine are the foam gaskets, they are starting to dry rot and don’t look good.
