Rick,
I think Tom meant the wrong relay in the stack. I keep coming back to more than just the relay you replaced as being the cause of the lights being on. Since you likely have multiple switches to control the lights I am inclined to rule out switch failure.
So that suggests an issue with the A-B system such as with a PLC or card, or there is an additional relay that has failed closed. The easiest way to check is to just pull each relay in turn to see if there is a second one in the circuit.
Where are you going to install the lites?
Jus wondering.
BCO
Tom, what type bulb did yours have before? Mine has the push in and twist.
Correction on that last post the new ones look like the one shown maybe tom can take a photo of the old one, they look simular but without the leds, I checked and new ones from Liberty were 2790 ea X 15 and 4 hr labor, go figure if these work great. But in fairness to Liberty the new fixtures are triple chrome plated brass, so I will polish up the ones I have, Gary
Hey Gary,
Will you be changing your side marker bulbs ?
Hey big Al, Doesn’t that Marathon of yours have all LED lights already? My side markers and other chassis lights are LED. The Gary and Tom duo are just changing out the converter lights to LED to not only keep up with the Joneses, but to get a step ahead of them.
I am confused Jon. Are they markers or cargo lights, where are they installing them?
DS
.Marathon has LED
I was wondering as Grote lighting has made some improvements in there side marker lights. Was doing some research on part numbers, specs.
Maybe… Gary and Tom might be on the same search,
Don,
The coach itself has the string of amber and a single red marker light running down both sides. But most of our coaches also have lights similar to the photo Tom posted that are installed by the converter and are typically used for patio lighting in a campground. In addition I think most also have what are defined as “cornering” or “docking” lights which look somewhat like a driving light and which have more intense lighting to help when making turns in the dark or when lane changing.
The “cargo” lights are not very bright, so if Tom and Gary have found a way to upgrade the lights we have to much brighter LED lights they not only will provide more light they are also likely to make you more secure because anyone monkeying around the coach will be clearly visible.
Thanks Jon, I understand what is going on now. Good move, low current draw, long-life, more light. I have done the same thing on my old hoopie. Used backup lights out of Peterbilt.
Don
Tom, Real interested in your LED upgrade on the cargo lights. Time to change mine out. Still love the look. Interested in new lens, gaskets and LED. You order from prevost. thx
Darrell
Tom.
Put new lenses and gaskets on all of my cargo lights just this fall. I am interested in the LED bulbs but yours look a lot different than mine. I have 12 volt round base tail light bulbs in mine. -
Darrell – The bulbs come from http://www.autolumination.com/ item Festoon
Item# 9 Led , Color: Super White , Lens: Rigid Loop. The stock bulb is a 212-2 (it has the little spring on end)The lights are from L & M Truck Parts http://www.lmctruck.com/, the lens are 36-4251 and the gaskets are 36-0510.
Chuck – Go to http://www.autolumination.com/ and in search type the bulb number such as 1157 and it will bring up LED alternatives.
Thx Tom, with the info… great help……. WOW, Where do you guys find the time for all the research….
With the LED bulbs, dont you need to kit out the bulb connection / pigtail also
