Dave,
I just bought a two-pack of carbon filters at HD, each lasting six-months. I get my filter “in the fridge” there too. My third filter is in my water bay and I got that on Amazon.
In addition to the coach filters, I have an exterior filter between city water and the coach. I use a clear unit so I can see the sediment, and change the filter when it gets dirty. Home Depot/Lowe’s have the filter units, all you have to do is put hose connections on the filter unit.
If you’ll just put a little good whiskey in the water as it comes from the tap before drinking it will take care of any germs that the filter might miss. Also eleminates the need for Listerine mouthwash.
I had the big filter under the sink replaced by Tradewinds in April. I am not sure what it filters. Does anyone have an idea where I can find my other filters on my ’03 CC. ?
Bill… I have four filters on my 04 CC XLII. One outside in the driverside bay #2 at the right hand side of the generator there is a panel that removes and it is up inside that panel which also has the water pump. The other 2 filters are under the kitchen sink. One big fat one for the instahot and one smaller longer one for the sink fauset. The last one is in the refrigerator. Don’t know how yours is set up but I Hope this helps
If you know your filter numbers or the filter system in your coach, try going to http://www.filtersfast.com They have a routine for delivery of replacement filters which is selectable by you and can be cancelled or revised to suit your filter needs. I have, as Jon calls it, a classic coach. That just means old with a water filter system installed by a previous owner and updated by the current owner several years ago. The system is a “Culligan AC 30 Good Water” system.
I just got a three filter replacement set to install prior to departure next Thursday.
Jeff, Thanks for the information. I knew about the one under the sink and I found the one in bay #2. Will look later today for the other. I put the part number into Amazon and received new filter in 2 days.
21 Ram 1500 EcoDiesel 4x4
