  • victor
    September 14, 2015 at 5:36 pm
    After reading Ben’s post ( http://prevostcommunity.com/forum/threaddetails.asp?Category=Electrical&ThreadID=2505 or see below), I am confident that I can just replace a few sections.
    These are 120v incandescent rope lights. They were originally all imported, and came in only 1/2″ or 3/8″ diameter. The individual bulbs are set up like “Christmas tree lights” in that for every section, the bulbs are wired in series. In this arrangement, if one bulb burns out, the entire section goes out. I can’t remember exactly how many feet were in each section, but they could only be cut at marked areas every 18″, with the extra stuffed back behind the cabinet or valance. When cut, there are lamp cord ends that have barbs on them to “stab” into the rope to hit the conductors that run to the bulbs. If you are so inclined, I would take one of the valances off so you could access behind it to the point where the lamp cord termination meets with the rubber-like light rope. If you pull them apart to expose the barbs, being EXTREMELY CAREFUL not to get shocked (120v AC power should be at the barbs).
    I have seen over time that either the barbs wiggle loose and no longer contact the wire in the end of the rope, or that one or more bulbs may be burned out, requiring you to replace the section of rope. At least this will get you access to replacing that section of rope, and let you verify whether or not you have power to that section. Since you have ANY of the rear rope lights working rules out a bad relay or the dimmer control. The only other connection points are 2 x 4 metal junction boxes buried at centralized “hub” locations in each side of the rear of the coach. If only two continuous sections of the rope lighting are not working, my bet is that it is the fault of the rope or the termination to that section of rope.
    Hope this helps.
    Ben Cummings
    Parliament Motor Coach
Page 3 of 3
