  • Ronald
    September 22, 2020 at 11:24 am
    Good stuff
    Thanks Jeff
    Chuck
    September 22, 2020 at 1:26 pm
    Hey Jon, I think the years for the truck light are in the mid to late 80’s.
    Unless LMC has changed the gasket material, the gaskets will not work to seal the assembly to the flat surface of the bay doors. The cab lamps have a slight curve to them and the gasket they ship with the assembly is hard rubber and some what thin.
    The gasket material on my 99 CC was a soft spongy material that would fill the gap.
    The gasket will not seal the assembly on the two outer edges.
    You can use them and take a little black silicone sealer and seal the ends of the light housing.
  • Robert
    September 22, 2020 at 2:18 pm
    LMC Truck has them.
    Late 80’s, early 90’s. 1 ton I think
    September 22, 2020 at 5:47 pm
    I got new the lens from here I believe they have the gasket also.
    http://www.classicparts.com
Page 2 of 2
