    November 18, 2022 at 6:23 pm
    DDEC3 don’t have a battery.
    November 19, 2022 at 2:06 pm
    Any chance you changed the position of the engine bay mechanic kill toggle switch ?
  • Unknown Member
    November 20, 2022 at 12:28 pm
    Got it running on the third try using starting fluid. On first two it fired, stumbled, and quite. Third time it fired and kept running. After warm up I took it directly to the indoor winter storage facility. I did add a quart of Power Service Diesel 911.
    Hopefully in the spring it fires right up; if not I’ll be in a better position to find out why. Thanks for the posts, private messages, and phone calls.
  • Jon
    November 20, 2022 at 4:08 pm
    Dick, glad you got it started. I’m just curious as to the outside (lowest) temps and if the block heater was used. Thank
  • terry
    November 21, 2022 at 9:02 pm
    So basically if I read this correctly, you still have no idea why it would not start, but you put starting fluid to it 3 times and it did finally start…correct?
    I would bet you still have an issue or multiple issues, but just got lucky and got it started so you could get it to storage.
    November 22, 2022 at 8:26 am
    Not true, Mark.
    A Liberty coach repairs itself. Some repairs take a while longer which is why Dicks coach took a while to get started.
    November 22, 2022 at 9:14 am
    That’s how they fix Liberty’s on Fakebook.
    Half a can of ether and get it in the barn. Fuhgettaboutit
    Later
    bv
    November 23, 2022 at 3:10 pm
    I’m ROTFL!!!!!!
    The outside air temps got down down to 24*F; which isn’t cold. I’ve started the coach in the past at -3*F. I had the generator on, the 120volt block heater running, and the Webasto running. IIRC I saw 120* to 130* engine temp on the engine temp gauge on the dash.
    We’ll see how things go when its time to take the coach out of storage.
    Thanks again for the concerns.
    November 23, 2022 at 5:06 pm
    DICK:
    “24*Deg isn’t cold” ?????
    This Florida boy puts a winter coat on at 69*Deg LOL
    Chuck
    November 28, 2022 at 1:20 pm
    Chuck I just started wearig long pants ten days ago!
    BTW … we’ve had ice on the river for ten days now.
    December 2, 2022 at 9:37 pm
    Intermittent spin no start, possible TRS or SRS.
Page 2 of 2
