  • Bus would not air up
    Posted by Michael on November 5, 2013 at 11:10 pm
    Well needed to change the oil in the coach today, so fired it up as I have to drive it out of the shop and flip it around so I can get to the engine bay and the coach would not come up on the bags. I could not even get the tag axle warning alarm or LED to come on.
    I had 120 psig aux air, so was a little confused. I got out the coach and went to the driver side electrical/air bay in front of the front tire. I checked the aux air water seperator and it had just a small amount of water and plenty of pressure, the gauge was reading 120 psig there as well. So I traced the air pressure line from the tag axle switch and found it goes to a manual regulator that is attached to the side of the aux air water seperator. Well there was pressure coming out of the regulator, but when I checked the blue and black air lines coming out of the manual regulator there was no air. So I left the lines off and backed off the lock nut on the adjustment handle. I then started to adjust it and trash flew out of the regulator. The trash was white, and I believe it was from water buildup. The prior owner may not have drained the seperator every day as they should have.
    The bus comes up on the bags quite a bit better now than they did when I first purchased the bus.
    Archived replied 12 years, 4 months ago 15 Members · 46 Replies
  • 46 Replies
    November 5, 2013 at 11:30 pm
    I think that is a pressure protection valve set at 75 psi
    November 5, 2013 at 11:42 pm
    What the pressure needs to be was going to be my next question.
    I need to figure out how to measure it. Theres no schrader valve to check it that I can see. I might have to tee into the line to check and set the pressure again.
    I know on my Bluebird, the tag axle pressure was set to 75 psi
    November 6, 2013 at 6:38 am
    Far too little attention is paid to the air systems in our coaches. Over the years I have seen a lot of damage caused by water in the coach pneumatic systems.
    The most vulnerable part of the coach pneumatic system is the accessory portion. This is likely the result of two things. The first is a failure to regularly maintain the overall system by draining tanks routinely and changing the air dryer elements before they fail.
    The second cause of problems is from what appears to be a common practice of storing a coach with the aux compressor on all the time. This is getting to be a very common practice due to the need to maintain pressure on the slide seal. The problem however is that the aux compressor actually back feeds air pressure into the system and it does no pass through the air dryer. The only device to catch water then becomes the small water trap located in the steer compartment on most coaches. That water trap needs to be drained frequently due to its small size.
    Michael outlines one type of problem and that is consistent with what is going to happen unless the air system is kept dry. Moisture in the aux system will ruin the Norgren valves, ride height valves and damage a lot of the pneumatic devices that the converter has installed.
    If you do rely on the aux compressor for extended periods be sure to drain the water trap AND the aux air tank.
    November 6, 2013 at 6:44 am
    If the coach would not come up to ride height, I would suspect the middle coil/valve on the 5 port norgren in the steering bay.
    November 6, 2013 at 7:01 am
    Are color coded Blue is suspension Fwiw That ppv is sort of in a low spot and when back loaded(pressure from other than designed operating side) it tends to stick. I have pulled the supply line and dropped a few drops of air line lube to help revive a dry valve.. Time and a little moisture creates a very unfriendly surface for air switching operations. The moisture actually effects the original assembly lube and the air line oil replinishes it and displaces moisture. TMI?
    November 6, 2013 at 7:59 am
    No Bob, That is exactly the kind of information all of us use. We store those tidbits of advice in our mental filing cabinet.
    November 6, 2013 at 9:17 am
    Jon why would they not run the aux air comp through the air dryer then it would be safe just wondering?At the converter block at back of bus where the air tank fill is , mine has block there where converter can tap into? It is marked converter with yellow tag , that block goes to air dryer first then lines go from there…If the air system was tight no leaks…..This may be a stupid question!!!!!!!
  • Alvie
    November 6, 2013 at 11:45 am
    I think the converter connection point at the rear is downstream from the dryer, and has actually originated from the front of the coach. Dryers are not just dryers. They function to an extent to control the compressor and that might not work with an aux compressor. Additionally I think the aux compressor would have to be a much bigger and possible rated for a higher use rate because from the dryer the brake circuits have to be satisfied before the aux system gets air. I have my aux compressor set at a low pressure and the protection valves and the pressure in my brake system would overcome my aux pressure from the compressor.
    I would guess a dryer could be installed downstream from the aux compressor, but if folks aren’t servicing the air systems now why would they service one more item in the system?
  • gary
    November 6, 2013 at 12:05 pm
    Thanks Jon was just wondering…..
    June 13, 2014 at 1:56 pm
    Couldn’t seem to start a new thread so I’m posting my message here.
    I am currently stuck in Hobbs, NM with the coach unable to come out of level mode. My coach is a 2005 H3-45. Arrived at camp ground and leveled coach with no problem. The next day got ready to go. turned off auto level. The primary and secondary air pressure readings were at 90 lbs. The Aux air was at 90 lbs. After turning off auto level the primary and secondary air pressure gauges went to around 70 lbs. The air alarm sounded, and the warning light on the air pressure gauges came on.
    Someone suggested that I pump the air brakes a few times hard to see if the solenoid switch was stuck and possible become unstuck. The pressure in both the primary and secondary air pressure gauges went to 25 lbs.
    I am now sitting here in Hobbs since Thursday morning waiting for a service truck to come out and look at the coach. This is oil country and the service trucks are mostly in the field, so it’s taking a while for them to get to me. Aux air pressure is holding at 90 lbs.
    Any suggestions from anyone who may have experienced this? I was told over the phone that it could be the governor on the air compressor.
    June 13, 2014 at 2:33 pm
    It is hard to diagnose what the issue might be with the information posted.
    First, if you add some coach and converter specific information to a signature line it will help give us a sense of how your aux systems are set up. Additionally in addition to giving us conversion information, some coaches have converter supplied supplements or changes to the Prevost Level Low system. If we know that the information can be even more specific.
    When you run the coach to air it up, will it reach 120 PSI on all three systems?
    If it does will the coach go up or down on your cammand? If so when you select the driving or road position on the suspension controls will the coach go to that position which is about 11″ from the bottom of the bay doors to the ground (unless the ground is uneven)?
    Tell us more. You may not need any service at all.
    June 13, 2014 at 2:52 pm
    2005 H3-45, Converter Featherlite 2007. Pressure doesn’t go up at all on the primary and secondary systems. It just stays now at 25 psi. The aux system is cycling off and on stays between 75 and 90 psi.
    June 13, 2014 at 3:52 pm
    May be the compressor or the governor. Have them take off the discharge line at the compressor and see if you’re getting air with the engine running.
    June 13, 2014 at 5:19 pm
    Service truck came and brought a governor. Not the right one. He removed our governor and carried it away to match. After he removed the old governor and left, we observed air and water coming from one of the hoses from he disconected. We were curoius that he did even want us to crank the engine. I guess they were satisfied that it was a governor problem from our description. Will keep the group posted on what we learn.
    June 13, 2014 at 5:36 pm
    Additional note: When the service guy removed what he called the governor we now notice the auxiliary air gauge shows 0 psi. The primary and secondary gauges still read 25 psi. Does this sound correct, or did he remove the wrong governor? With the auxiliary pressure now zero, what capabilities have we lost in the coach until the governor he removed is replaced?
Page 1 of 4
