The regulator and check valve should arrive today and I will replace them. While I am at it i want to replace the fitting marked by the red arrow in the picture. Al has been very helpful in directing me with part numbers and a source to order. Anyone know part number of this?
Hard to tell in the photo, but is that a pressure relief valve?
If so they are generic, but you need the upper limit to match the compressor. You don’t want to put a 175 PSI on a 120 PSI system. If you couple the aux system to the bus accessory system you need at least 130 PSI because that is the upper limit for the Prevost.
Thomas who manufactured the compressor might be able to help with that.
FWIW…is yours leaking ?
