  • Yikes -lost jake brake coming down Siskiyous pass
    Posted by Gerald on January 16, 2016 at 6:41 pm
    I noticed the coach not slowing down as usual using the jake brake and got the front brakes pretty hot despite being in a low gear. Made it down slowly but could smell the front brakes a few times. Now in Corning, CA.
    I’m trying to trouble shoot the problem before I go over another pass. I have the jake switch on but the jake is not engaging. No error messages or lights. Engine is running fine so I don’t think it is a mechanical problem.
    Looked for some breakers or relays that operate the jake but could not find any in the electrical compartment below the driver or in the rear above the engine. The jake brake is not mentioned on the schematic on the engine door or below the driver.
    Any idea what to look for? I imagine the DDEC operates the jake based on the switch position. How does it do it? Is there a solenoid that engages the jake?
    I’d appreciate any help/pointers
    Thanks,
    Gerald
    Peter replied 10 years, 9 months ago 9 Members · 9 Replies
  • 9 Replies
    January 16, 2016 at 7:49 pm
    Look carefully in that chassis electrical compartment below the driver. It’s easy to overlook a popped breaker because it’s just a little round pin sticking out of the breaker further than any others. If you find it, push it back in and replace the switch on the dash.
    This from my experience, be vintage sensitive.
    January 16, 2016 at 9:03 pm
    I did check the breakers, none were popped. I’ll double-check tomorrow. There should be Jacobsbrake control unit somewhere but I have not found it yet.
    Gerald
  • Michael
    January 16, 2016 at 10:38 pm
    Gerald,
    My jake has dropped out a few times over the years and I have never found any answers. One thing I have done that caused it to work again was to lift the accelerator with my foot. Some one had suggested that the switch there was showing I still had my foot on the gas. Another thing was to turn off the bus and restart the engine. That has always worked. It has only happened a handful of times and of course it has never duplicated with an expert around.
  • Steve
    January 16, 2016 at 11:24 pm
    Davy,
    thanks for the tip. I’ll try it tomorrow.
    It is surprising how little engine braking there is without the jake.
    Gerald
  • Chris
    January 17, 2016 at 6:16 am
    I haven’t had a Jake on a Series 60, but on my 8V92 in the rear electric box there were two posts that when hot would actuate the solenoids for the Jake.
    At idle I would use a jumper from the 12 Volt post to one of the Jake posts. (I think on that coach they were posts #1 and #2) With power to the post I could hear the Jake engage and the engine lug down. I would do that to each of the posts to verify the Jake was working, at least at the engine. If I powered both Jake posts I could stall the engine.
    I suspect but do not know for sure there is a similar set up on Series 60 coaches. By doing the test which only takes a couple of minutes you isolate where to look for the problem, either at the key pad which controls the Jake or at the rear.
    January 17, 2016 at 8:28 am
    A couple of things to loook at. First check the gas pedal, making sure it comes all thje way back. Be sure the floor mat has not snuck up under it preventing it from returning all the way. Second try turning the cruise off, sometimes the cruise will disable the rake.
    Good Luck.
    Mikee
  • Larry
    January 17, 2016 at 6:29 pm
    Jake was back all day today. Of course, I was traveling in the central california flatlands. So did not need him really. We’ll see if he sticks around on the next mountain pass.
    As you guys pointed out, the cause of my problem was probably the throttle position sensor (gas pedal) not fully going back to idle. This prevents the jake from coming on. The DDEC simply figured I was still on the throttle, no jake for you. Thus no codes or lights.
    Based on your feedback, I made sure the gas pedal mechanism went through its full range and did the recalibration (3 x fully depress gas pedal with the ignition on). Good so far.
    You guys are great! Thanks for everyone’s help.
    Gerald
    January 17, 2016 at 10:21 pm
    Happened to me too. Jake would stop working and I would have to shut the coach off and then turn it back on to make it work again; it continued to fail every five hours or so. I made it to Marathon a couple days later and they replaced the Throttle position sensor. All is well since.
    It’s disconcerting to say the least. I lost mine on CA 299 west of Redding heading to the coast.
    February 21, 2016 at 11:54 am
    Some explanation and additional discussion in –
    Loss of Jake, and other ECM related problems
    http://prevostcommunity.com/forum/threaddetails.asp?Category=Chassis&ThreadID=5284
    Ed Roelle
    810-516-9888
