  • XLII D60 Engine Valve Cover Access
    Posted by steve on August 18, 2021 at 1:48 pm
    Pic shows what looks to be a removable insulated area above engine. Curious if anyone else has same setup & is it removable to give enough clearance for valve adjustment ?
    John replied 5 years, 2 months ago 9 Members · 11 Replies
  • 11 Replies
    August 18, 2021 at 5:01 pm
    Yes and Yes!
    We have a removable finished floor section. Which probably means nothing since you have a different conversion. Ours is a 2001 Marathon. Remove the finished floor section and 6 bolts hold the access hatch in place.
    What you need is someone with a Parliament conversion that has removed the hatch to chime in with more specific knowledge.
    Best of luck!!!!!..
    August 18, 2021 at 7:34 pm
    If it’s a N/S bed, it’s most likely under the bed. Some disassembly required!
    If it is E/W it could be most anywhere including some inaccessible places requiring major disassembly. In most cases it is less accessible than money can buy.
    (seriously, but a bit tongue in cheek). You can try to guessitmate the distance from the access panel to something on the side of the bus and translate that to the interior under floor location and try peeking in and around everything in that area.
    August 18, 2021 at 9:28 pm
    Steve, here’s a photo of the top side. Nothing but a little fun…just removed mine to install a new CTS coolant temp sensor.
    August 19, 2021 at 9:53 am
    Jim: I need to access that too. We have a 99 Liberty XL45, east-west bed. What did you do to access the top of the engine?
  • Gerald
    August 19, 2021 at 11:39 am
    if you do not have a Jake brake, the valve cover can be slid off.
    Larry Nelson
    2002 XLII VISION
    2019 Buick Invision
    Hurricane, UT
  • Roscoeapproved
    August 19, 2021 at 1:29 pm
    Tks all. Do have jake break. Gonna raise bed and investigate.
    Jeff and Lindsay
    91 Marathon XL
  • James
    August 19, 2021 at 8:37 pm
    Dick, just pull the 4 drawers out of the rear middle section dresser located under the closet. Then you will notice Liberty has engineered the cabinet center section and cross brace to be easily removed. Once those pieces are out of the way, you will find 6 bolts holding the aluminum covered, insulated cover down. BTW, the top large drawers lift off of the slides, the bottom drawers just pull out after reaching the slide stop. If you have additional questions I’ll be happy to help.
  • Ken
    August 19, 2021 at 8:57 pm
    Dick, et al, I found a picture for you. Yours should be similar.
    August 19, 2021 at 9:46 pm
    Thanks Jim!!!!!
  • James
    August 31, 2021 at 5:16 pm
    Jim, that box looks similar to mine when bed is raised. How was the box removed ?
    August 31, 2021 at 8:12 pm
    Steve, 6 bolts hold the cover down, it will be stuck due to the weatherseal/gasket, so just carefully pry it up. I tried to convince my wife to climb between the fan and turbo, so I would not have to disassemble the cabinet, but she refused. LOL, Hey but she does a great job of ironing my pants and shirts…and packs the bus for trips among other things .
