  • Window Part
    Posted by Chuck on November 18, 2019 at 11:12 am
    Would anyone be able to tell me where this part for the window can be located? It drives the mechanism that opens and closes the window. Maybe would have to come from the graveyard of old buses. Prevost doesn’t stock them any longer and Jeff cannot find one.
    Archived replied 6 years, 11 months ago 6 Members · 5 Replies
  • Larry
    November 18, 2019 at 2:39 pm
    Chuck,
    When a part is no longer available we have two choices. Abandon the mechanism, in this case close and seal the window forever, or get the part made.
    That part is apparently brass but it could be steel or aluminum and it would work just the same. Find a local small machine shop and ask them to make it for you. Whatever the cost I am sure it would be less than having Prevost remake the part.
    Finding one it a junk yard for buses would likely be similar in difficulty to finding an honest politician because the number of seated coaches which do not have our type windows is very large compared to conversion and few conversions using that part are worn out. Maybe you can find one that burned or was in a serious wreck, but I bet it would be quicker, cheaper and easier to just make one.
    If you are patient, and have a few simple tools you could probably make one yourself.
  • George
    November 19, 2019 at 7:35 pm
    Thanks Jon. I will look for a machine shop
    November 20, 2019 at 10:36 am
    Maybe…
    If you think that you could take to measurements and draw it in a simple cad program…maybe this could help.
    EMachineShop.com
    Just throwing out another idea.
  • Roy
    November 23, 2019 at 1:34 pm
    Thanks Tim
    December 1, 2019 at 12:53 pm
    Chuck, did you get the part sourced? If not, I believe I can get you fixed up, my son has a lathe and does milling jobs. He can make this out of aluminum if you’re interested.
