  • Wilkerson Aux Air Filter
    Posted by Archived on July 30, 2012 at 10:05 am
    Be sure to check out your filters, the view from outside is deceiving. You take a look, no water and you think all is well. The filter housing needs to be removed to check the condition of the filter and needs periodic changing. Mine was in bad shape due to corrosion of the filter housing and is heading for the junk pile. This fitler was for the aux compressor and once again, these compressors make a lot of water.
    JIM replied 14 years, 3 months ago 2 Members · 1 Reply
  • 1 Reply
  • JIM
    July 30, 2012 at 11:06 am
    I’m in total agreement with Tom.
    The auxiliary air
    compressor does not have the benefit of the auto blow down used on the engine
    compressor. This means all water must be collected before it gets to the aux
    air tank and the Norgren suspension valves. I’m fortunate to have a Jun-air auxiliary
    compressor and can level my coach quickly without the engine running. I also
    have a Microphor toilet that requires air to flush. Some of the Microphor units
    have an electric flush timing valve and some of them use a pneumatic timing
    valve. I’m unfortunate to have the fully pneumatic version that is very susceptible
    to problems caused by moisture. After taking it apart and cleaning to remove
    moisture a few times I added a desiccant drier after the standard air water seperator
    Tom displayed. Problem gone, who wants a Prevost with toilet problems
