  • Why would the aqua hot fuel pump be running
    Posted by George on August 23, 2019 at 8:27 pm
    Tonight I heard a motor sound and found the aqua hot fuel pump running.
    Haven’t done anything other than turning on 12 volt master to do some cleaning to the new to me coach.
    Never heard the pump run the numerous time there last couple days cleaning
    DON replied 7 years, 2 months ago 5 Members · 4 Replies
  • Roscoeapproved
    August 23, 2019 at 8:57 pm
    Perhaps there is a leak or its sucking air. The pump is trying to satisfy the pressure switch.
    Jeff and Lindsay
    91 Marathon XL
    August 23, 2019 at 9:12 pm
    The Aqua Hot fuel pump is run by a gear on the blower motor shaft. So, if the fuel pump is running, so is the blower motor and exhaust air is coming out of the exhaust pipe.
    If the blower motor is running for more than 3 minutes after the firing has stopped, you have a failed control unit.
    You may call me before 9 pm central time and I can assist you diagnosis the issue. Or anytime Saturday after 8 am.
    Rudy Legett 7 one 3 8 one 8 3234
  • Gerald
    August 23, 2019 at 9:19 pm
    Thats what i meant. What Rudy said.
    August 24, 2019 at 1:50 pm
    Did you solve your concern?
