  • Why Motorcoaches Burn (Fire)
    Posted by Archived on March 28, 2014 at 10:22 am
    Some of you may have seen this 2007 publication: Why MotorCoaches Burn.:
    Taken from the article:
    Preventative, Periodic, Annual and Daily (Pre/Post Trip) Maintenance and Inspection Items
    • B+ Cable at alternator secure (stud, bracket and clamps in position)
    • Alternator oil lines and rear cover plate secure and not leaking
    • All alternator electrical studs covered with rubber boots
    • Remote Jump Post secure and stud covered with rubber boot
    • Starter cables secure and routed properly
    • Bulkhead connection for B+ cables (starter and alternator) secure
    • Engine compartment clean/dry of fluids
    • Engine and Transmission fluid connections/hoses secure and not leaking; sensors not leaking
    • No leaks dripping onto pavement
    • Hub-Caps; no visible leaks, rubber plug in place, sight glass is clear, oil at proper level
    • Oil seals are in good condition, no leaks (only observable from under vehicle)
    • Disc brake rotors (if visible) clean with no bluing
    • Dual tires not making contact with each other
    • Turbocharger oil line(s) not leaking, waste gate pivot pin not leaking oil
    • Exhaust system; no oil exiting from muffler, no excessive blue smoke (turbocharger oil consumption)
    • Engine has appropriate performance (torque)
    • Auxiliary heater not leaking fuel
    • No active / Illuminated A.B.S. dash light*
    *The illumination of this light could indicate the potential onset of a loose wheel bearing, hub run-out, wheel bearing failure or a skidding or locked tire/wheel.
    Archived replied 12 years, 8 months ago 1 Member · 3 Replies
    March 28, 2014 at 10:49 am
    Excellent post.
    Let me add a couple that we know also play a role.
    Dragging brakes
    Dry bearings
    Under inflated tires.
    There are numerous reasons why our brakes drag. I don’t have any way of determining if dragging brakes occur without warning, or if they drag more and more over time, but our coaches have the ability to continue driving as though nothing is wrong even if a brake is locked.
    Dry bearings may not seem like a potential fire starter, but when a bearing is run without the proper lubrication that they get when the hubs and differential are filled as required they get very hot, very fast and that heat travels to the wheels and tires.
    Under inflated tires are a serious threat of fire. If the tire doesn’t blow out and tear up your coach as pieces come apart the heat generated can easily start the casing on fire and tire rubber burns very hot, likely destroying the entire coach.
    David’s list is equally important and all of us have to be alert to all the things he has mentioned, almost all of which will be found with a visual inspection. Be aware there is no protection on the battery cables or the alternator cables until they get to the circuit breakers. So any direct contact with those positive cables and a chassis ground is going to create a lot of arcing electric and any fuel source including the cable insulation begins the fire.
    March 28, 2014 at 2:30 pm
    My good deed of the day Jon! 🙂
    March 28, 2014 at 2:36 pm
    David,
    That was a great post because it is a reminder that with a little effort none of us has to be a victim.
