  • webasto smokes after shutdown,
    Posted by Francis on October 15, 2015 at 9:13 am
    installed new high pressure nozzle replaced fuel filter , cleaned burner assembly, still smokes after unit goes through its cycle,. Does not smoke on start up at all–?? What should I look for . On a 1990 liberty
    Archived replied 11 years ago 3 Members · 4 Replies
    October 15, 2015 at 1:08 pm
    If the fuel solenoid does not close crisply. It might have a puff of smoke on shut down. A puff is of no great concern. If it runs with a clear exhaust just carry on.
    The burners I work on are 50,000 btu, the fuel pressure set at 145 psi and the nozzle is a Danfoss brand 0.35.
    Install procedure for the nozzle is tighten nozzle, loosen a quarter turn and tighten again.
  • Ronald
    November 18, 2015 at 3:32 pm
    Rudy, Liberty installed the DB2020, and 80,000 btu unit because it always heats the engine block as well as heat the coach interior, so the nozzle is a .65, not the .35 you would utilize on the DB2010 50,000 btu unit. Just FYI.
    November 18, 2015 at 4:19 pm
    Thanks Ben. I appreciate the extra info.
    I am Aqua Hot oriented and the 80,000 btu burner is a new animal to me. I do not carry parts for it and the one I saw looked very different to the 50,000 btu burner I am used to.
    As long as we are discussing a Aqua Hot Heater and burner or the 50,000 btu Webasto Heat Exchanger Burner, I am conversant on those.
    It is good to know who I can refer to when the 80,000 btu burner is shown to myself to help the owner resolve his concerns. Bless you for your expertise and experience.
    November 19, 2015 at 9:19 am
    Very welcome Rudy. We are all in it together lol.
