  • Webasto Problem
    Posted by Robert on May 16, 2015 at 5:00 pm
    Webasto Guru’s My Brother-In-Law’s Boss is having a Webasto problem on his Prevost. The Webasto is a brand new out of the box replacement unit. It starts when turned on But once it shuts off it will not restart Thermostatically. You have to manually restart it from the dash switch. Any ideas about the problem would be appreciated. I am not familar with Webasto as we dont use them in Entertainer Coaches. It is a Liberty Conversion, 2002 model. We have tried all we know and need someone with more expierence.
    Thank You All in Advance For Any Help.
    Robert
    Archived replied 11 years, 5 months ago 2 Members · 2 Replies
    May 16, 2015 at 5:39 pm
    Rudy Legget, He’s an advertiser. Geo.
    May 16, 2015 at 9:38 pm
    Robert,
    I need to know the model of the Webesto Burner. The one I am familiar with is the 50K BTU burner. Some are installing the 80K BTU burner for which I have no experience.
    I also need to know if the light in the inside switch stays on when the burner will not restart. If the light is off, the burner has faulted for some reason.
    A burner that faults while burning can be caused by the flame sensor’s resistance increasing as it heats up finally stopping the fire. Or the conrol unit loosing contact with the control thermostat stopping the fire. With everything being new, the above is not likely.
    Running out of fuel is another reason. You need more, more the better, than 1/4 tank of fuel to run the burner. The supply fuel line to the burner leaking air is another cause. This is a new install so maybe something did not get tightened correctly.
    Wish I was there to use my test box to see what is going on. If you can be at the burner with a volt/ohm meter, please call me and I will see what I can do over the phone with you all. I am available via the phone after 8 am till 8 pm most days including Sunday. If I can not talk when you call, I will call you back fairly soon. Most times I can talk when you call. This Sunday, I have a lunch get ogether from 11 am till 2 pm.
    Rudy 713-8 one eight-3234 All the best.
