  • Webasto Circulation pump
    Posted by Greg on January 16, 2017 at 4:33 pm
    In the past I would leave all the switch (mine are in the engine bay) to the Webasto on and when there was a call for heat the circulation pump and burner would turn on. Now with the same switches on the circulation pump alway runs with out the burner firing up, with no call for heat. Is the current situation normal? Those that have switches inside the coach does you circulation pump turn on even without a call for heat from the thermostats?
    Greg replied 9 years, 9 months ago 1 Member · 0 Replies
