  • Water tank fill wont
    Posted by David on September 16, 2013 at 8:24 pm
    When i push the tank fill botton it wont fill the water tank , I can hear the solonide on the water line click but it may not be allowing water to flow how can i repair this it will be hard to replace due to the clamp on plastic lines ,
    Archived replied 13 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
    September 16, 2013 at 8:57 pm
    If the water inlet valve is, in fact, opening, the most common problem is a clogged screen. I have seen this happen several times.
    Hopefully it’s a quick fix…
    September 17, 2013 at 3:35 pm
    Odd, I’ve had an electrical failure which didn’t allow me to operate solenoid but I’ve never had your problem.
    In any event, am I correct in assuming you normally fill tank until water overflows through a vent tube? If so, to get you moving, you can disconnect the fill hose going into the top of the tank and fill directly with a garden hose.
    September 17, 2013 at 6:18 pm
    David, my inlet valves are manual so I can’t help if it is a solenoid or valve problem, but I recently had a situation where after manually opening the fill valve I still could not get water to flow to the tank. It turned out that the in-line pressure regulator between the water inlet and the tank fill valve was preventing water flow. If you have a permanently installed pressure regulator, that may be the problem. Mine is braised into the copper plumbing so not removable (by me), but I was able to disassemble the regulator from the bottom and remove the guts, which solved the problem. Those regulators are intended to have constant pressure on them, but in an application like a bus, which might have long periods with no pressure applied and no water in the valve at all, the internal seals and springs deteriorate. The one on my house still works fine and it is over 40 years old.
    September 20, 2013 at 9:56 pm
    There is a preasure regulator just befor the elect valve and i am unable to get well water in my line also .. I will try to pull it out this weekend and check it thanks for the idea’
    September 22, 2013 at 4:09 pm
    You were so very correct the preasure regulator was not alowing any water through. I disambled it and could not see any way it could quit working but it did ,, this forum has helped me so many times , what a great bunch of members here. Thanks again for saving the day. O one more thing i need the six correct numbers for Floridas wensday lotto.
    September 22, 2013 at 9:44 pm
    David, good to hear it was such an easy fix. Shucks, I had the Fla numbers but can’t remember what I did with them…they were simple too.
  • JIM
    September 23, 2013 at 6:18 am
    Has anyone ever wondered why psychics never win the Powerball Lottery drawings?
