  • Water tank drain valve
    Posted by Peter on March 20, 2014 at 12:14 am
    Well I went to put water in aux water tank when I filled it the gate valve was leaking , the valve is used to empty aux water tank, it’s hooked to main tank , they both are used together, I pulled it out cleaned valve put back in , still leaked , so I had new one took it out replaced it with new one all good now , good thing I had new one, I keep main tank full in winter because I run the water everyday out tap or flush toilet …
    Chas replied 12 years, 6 months ago 4 Members · 4 Replies
    March 21, 2014 at 3:35 am
    Aux water tank that is a first for me, now idea there would be a need.
    March 21, 2014 at 8:30 am
    My Royale is about the best dry camping coach going , lots of water not much power draw and the only thing the aux compressor is needed for are the gen air bags maybe once a month
    March 21, 2014 at 8:51 am
    My coach has (2) tanks. A water tank and a tank labeled bottle water tank side by side. 100 gallons each. Bottle tank is for the icemaker water and instant hot tap at sink. Has 2 sureflo pumps and toogles switches for both. Has a maze of valves you can run either tank dry. You can also draw out of a 5 gallon water bottle if needed. Seems like overkill but you don’t run out of water.
    March 21, 2014 at 10:13 pm
    Glen do you have a RO system for one of the tanks or do you fill it only from a special source?
