  • Water pressure switch
    Posted by Archived on June 11, 2015 at 3:36 pm
    The water pressure switch on my 94 CC doesn’t always kick on. If I give it a tap it’ll power up the water pumps, I removed it, did my best to lube up the contacts, but still the same after I reinstalled it. It’s a Furmax 69WA4Z2040, are these still available or a suitable replacement? I’ve looked online, haven’t come up with anything yet.
    Bryan replied 11 years, 4 months ago 4 Members · 4 Replies
    June 11, 2015 at 3:50 pm
    D&J,
    If it looks like a well control water pump switch you can use anything that functions like that. Almost always available at Lowe’s or Home Depot
    June 11, 2015 at 5:20 pm
    Yep, that’s what it looks like, it just has 2 terminals for the 12v connectors instead of 4 like the 110’s use.
    June 11, 2015 at 5:23 pm
    Look for it under FURNAS instead of Furmax. Also I believe that Hubbell may have taken over production, so you may also look at Hubbell, but the FURNAS with the Furmax number should give you some results.
    3F
  • Bryan
    June 11, 2015 at 7:04 pm
    Jon & Fred, thanks. Found the exact replacement through Furnas.
