Water Heaters
After reading Dick’s post on replacing his water heater element, I decided to open up my water bay and look at both water heaters for possible leaks. After unscrewing all the screws on the stainless steel cover, there were two rivets on top which I didn’t feel like popping since both are still in good working order & I don’t see any water on the bay floor.
My question is there any other way to determine if your water heater is rusting out before it actually starts leaking out the bottom? I was able to see the insulation but without removing the rivets I couldn’t see the actual water tanks. I looked at the diagram and it shows access from the side, but then I’d have to remove multiple hoses to open up the system before inspecting it. I’ve changed both gas @ electric water heaters in my house in the past, but of course the access is the biggest issue when dealing with our bus.
