  • Water Heater Replacement Recommendation
    Posted by Ronald on July 29, 2021 at 11:47 am
    Time to replace the water heater. What are the PC recommendations?
    Ron
    Dick replied 5 years, 3 months ago 9 Members · 13 Replies
  • 13 Replies
  • Terry
    July 29, 2021 at 4:30 pm
    What do you have now? The answer is almost totally based on using the available space.
  • Roscoeapproved
    July 29, 2021 at 10:01 pm
    If that 40 gal unit is your current one, I’d find another like it. Mine is only 12 gallons!
    Jeff and Lindsay
    91 Marathon XL
    July 29, 2021 at 10:37 pm
    I noticed that to be a 240 volt dual element unit. Mine is a 16 gallon 110, is in the water bay and does a great job for 2 people back to back showers… I have never seen one of that size in a coach.
    July 30, 2021 at 6:44 am
    Ron,
    If that water heater is in your private 767 this goes in the aviation category.
  • darrell
    July 30, 2021 at 9:58 am
    Where did they find room in your Prevost bus to install a “40” Gallon water heater ? A 40 gallon water heater is probably 5 feet tall .
    July 30, 2021 at 10:27 am
    Raritan makes electric water heaters for Marine use,It’s just like a bus. They make all kind of sizes and the electric element is correct for amps for a bus, not 220 v they have a top mounting hole welded to tank for extra support they are little pricey and most buses have 2: 18 or 20 gallon water heaters, that’s what these water heaters are made for Buses or boats not residential.
  • Paul
    July 30, 2021 at 2:11 pm
    Hello, Jeff. This is not in the 767!
  • Paul
    July 30, 2021 at 2:27 pm
    http://www.whirlpoolwaterheaters.com/support/E2F40LD045V
    Link to Whirpool PN in your picture. There is a spec sheet on your heater at this link as well.
  • Ronald
    July 31, 2021 at 3:53 pm
    Al,
    It is the fourth bay on the passenger side. Height is 31.75″.
    R
    July 31, 2021 at 3:54 pm
    Richard,
    RE: Size. I have never seen one this size in a coach either. There is a lot in this coach I have never anywhere else for example a full-size jetted tub. I plan to replace the tub with a walk-in shower, but have not gotten around to that yet.
    R
  • Ronald
    July 31, 2021 at 4:13 pm
    Curious. What about an electric tankless water heater? Anyone ever seen one installed in a coach?
    R
  • darrell
    August 1, 2021 at 8:29 am
    Art,
    How are two Raritan’s set up? Plumbing wise?
    Easy enough to find a residential low-boy water heater. I do, however, like the idea of going to a water heater specifically designed for bus.
    Ron
  • Dave
    August 1, 2021 at 10:12 am
    Hey Ron! They don’t make a AC volt tank less water heater, It would take to much power to make it work . As far as the plumbing Water goes in one heater then out then to 2nd heater then out. Electric wise add 1 more 20 amp 120v breaker and some Romex, Raritan is tough and reliable made not to rust inside and out. I’ve replaced over the years 2 Aqua Hot systems with a single Raritan 20 gallon water heater, you have to add a check valve on in coming water line not a problem, I install a Raritan in our 1980 Liberty years ago worked great. The base screws down to bottom of compartment and then you make a bracket for the top support and it won’t go anywhere. Also you can by it with or with out a heat exchanger, so when your driving it heat’s up.
