  • Vent Fan
    Posted by Larry on November 19, 2012 at 2:28 pm
    I am looking for a NICRO fan assembly or fan motor to replace the one that died. The Co. was sold to Marineco sometime ago and they no longer carry the fan or parts that I need.
    This is the fan refered to as the “fart fan” by parts folks, it is 8.75″ X 2.75″ and requires a 4.5″ opening in the ceiling. They usually have a stainless trim ring around the top of the assembly that sits on the roof.
    The fan I need is 110v, there are a few solar powered one on the market.
    Thanks for your help.
    LarryB
    2000 CC XLV
    Robert replied 14 years ago 5 Members · 6 Replies
    November 19, 2012 at 2:51 pm
    Larry.
    Are you sure it’s 110v? I would be surprised to find a low amperage motor so closely exposed to the elements being AC powered.
  • Larry
    November 19, 2012 at 11:03 pm
    Gil, I assume it is 110v. I blows a 7.5 fuse in the mother board.
  • Robert
    November 20, 2012 at 5:54 am
    Larry,
    My bet is our fan is a Nicro N20354S. As you’ve discovered its discontinued. So, you have three choices, as I see it.
    • Replace your fan with a solar powered version of the same. This should ensure the same fitment (you should check on fitment first).
    • See if you can find a replacement motor or have a motor shop rebuild it. FYI. it may be too small for a motor shop to care.
    • Change the fan out with a different 12V fan.
    What ever your cure, let the rest of us know. The form factor of our fan is most widely used on boats. Doing a quick search it looks like all new versions have went to solar powered.
  • Ronald
    November 20, 2012 at 10:44 am
    Gil, I fell into the 110v idea as the fuse was in the Motherboard which I thought was all 110v. “Head up and locked” I guess.
    Might have a source for the fan, should know tomorrow–will post the result.
  • Rick & Denise
    November 20, 2012 at 12:24 pm
    Hi Larry,
    Search for item 120825504508 These are the 12 volts model with rechargeable battery for nighttime operation. The cost is $830 including shipping. That is a very low price, considering the new cost was easily 3 times as much.
    Cheers,
    Ronald
    November 20, 2012 at 5:04 pm
    Thanks Ronald, seems these may work.
