  • Using shop air to air up coach
    Posted by Jim on February 27, 2023 at 11:10 pm
    1. How do I air up coach by using shop air and what to do I watch out for thanks
    Bill replied 3 years, 8 months ago 4 Members · 4 Replies
    February 28, 2023 at 7:06 am
    If you want to air up all 3 systems?, primary brake tank, secondary brake tank, aux (suspension, etc) tank, there is a schrader valve above the chassis batteries at the right side rear most door hinge. I added a ball valve and a quik connect fitting to mine (see pic).
    If you want to air up only the aux/suspension etc tank? there is a schrader valve in the front left steer compartment near the floof on the right side at the door entrance.
  • Jim
    February 28, 2023 at 9:42 am
    Use a pressure regulator set at about 115 psi. I added a valve as the oher post as well
  • Isaiah
    February 28, 2023 at 10:55 pm
    Thank you don never used it like that yet. Thank you
    February 28, 2023 at 10:58 pm
    Thank you Mikee really appreciate it
