  • Using prevostcar.com Manuals
    Posted by Bob on January 13, 2015 at 12:03 pm
    This for everyone. Will direct flow thru site For Mike T with clutch problem. prevostcar.com—click Home/Main site–at top click publications select tech pub— choose XL bus skip to type of manual==maintance—Manual section and slect clutch. go down hit search–screen on right should apear—click on blue line and it will down load to your computer.. That will get Mike to his area. For others that have proconversions. you can enter more info. For how it was delivered to your converter you can enter last letter in your serial # and last four numbers. Example: W 6553 is mine. It will give you info and updates from prevost not converter. Sometimes less info is better. The W=1998 the 6553 is unit ## With pre 2000 coaches not every serial number is there. Bob
    Dick replied 11 years, 10 months ago 2 Members · 1 Reply
  • 1 Reply
    January 15, 2015 at 9:42 pm
    Thanks Bob! Got the manual today. It will help a lot to solve the clutch problem.
