UPPER RAMCO MIRROR WON’T ADJUST
Posted by joel on September 8, 2019 at 2:27 pmusing my electrical control. I can move it by manually pushing on the glass. This is the small convex piece. Anybody run into before?
1999 XLV X-6872, liberty #440gordon replied 7 years, 2 months ago 8 Members · 9 Replies -
Joel, before trying to pull the mirror off and seeing if it is the motor, check to see if power is getting to it. The easiest place I think is to remove the 4 screws holding the arm and if my memory is correct there is a plug or connector there. From the plug the multitude of wires goes to the motors and heating elements. I assume if there is power at the connector the motor is bad, but I think there are two so if both do not work it is wiring or switch.
The above is nothing more than a guess.
Interesting. As I think about it, there probably are two motors on each glass; one for vertical and one for horizontal. Do you know if Prevost wiring diagrams include mirrors?
Had that same issue on driver’s side. Removed upper glass, found a connection pulled apart. Lengethened that connector a little, cleaned up the others, and reattached mirror glass. My glass came off so easy it likely was close to falling off anyway.
Joel,
May or may not help you, but if you look at my video towards the end, you can see the motor assembly..
Thanks for all the help but it was operator error. The Prevost replacement switch for that mirror which I had installed long ago is a 3 position switch with a neutral position. oops
Not to worry, Joel.
We will not say a word to anyone. This will be strictly between you and about 4300 of your closest friends.
Actually, that’s good news. I had no idea I had 4300 friends…must not know me very well!
Obviously I was joking, but one thing is evident and that is if a PC member needs help other members go out of their way to provide that help. So we do have 4300 friends.
