Update Heater fan for Webasto, possible?
Posted by Archived on November 20, 2017 at 12:59 pmHarry replied 8 years, 12 months ago 4 Members · 4 Replies -
Good luck with a computer type fan. Blowers typically move much more air than fans. Maybe the variable motor speed would be a better solution.
I don’t think changing fans is going to resolve the issue. Yes they draw some current, but the guilty party to the consumption of electric is more than likely the circulating pump.
You will not get the air movement from computer type fans, I think generallly they are rated around 100 to say 170 CFM.
The Red Dot motors and the squirll cage fans should put out significantly more air. If they are making a lot of air and consuming too much power, they may be fixing to go south on you. They should only draw an amp or so.
As Jon said the circulation pump or pumps can be a significant draw.
My 99 CC uses two M&P 12 volt pumps and when they are needing replacement they will easily blow the fuses.
