  • Ugly fix revisited
    Posted by Brian on September 11, 2021 at 10:27 pm
    Installed the Ugly Fix late last year and was pleased how the oil cleaned up and the mileage made a slight but positive improvement. Have recently noticed a fair amount of white smoke, not condensation, on start up and under acceleration. Is their a correlation? Am about to change back to the factory sensor but would appreciate some knowledgeable and unbiased input (or reference thereto). Thanks
    Bill replied 5 years, 1 month ago 10 Members · 11 Replies
  • 11 Replies
  • Jeff
    September 12, 2021 at 8:58 am
    White smoke is typically, bad injector, low compression, antifreeze (coolant in today’s world).
    September 12, 2021 at 10:00 am
    Agree with Mike above…
    No need to switch back to the old sensor to test.
    ***Have “heard” but do not know this for a fact, that if your Ugly Fix works now, be certain to not allow anyone who works on your bus to update the DD software as afterward the UF may no longer work.
  • Glenn
    September 12, 2021 at 10:43 pm
    That be the case with the white smoke I would give a call to American Fleet in Springfield, MO
    Just a WAG …#6 cylinder with a leaking head gasket.
  • Robert
    September 13, 2021 at 11:25 am
    Thank you gentlemen. Will proceed as suggested. Unfortunately we are a long way from MO but will find an independent Detroit mechanic for consultation.
    September 14, 2021 at 10:41 am
    BEST WISHES, Brian. Please let us know the outcome.
    2005 XL Thompson Coach
  • Joe
    September 14, 2021 at 3:14 pm
    Under a load? white smoke is water, head gasket maybe, and hope NOT a cylinder, change antifreeze lately??????
    September 15, 2021 at 10:01 am
    Could be a leaking injector tube in the head.
  • Robert
    September 19, 2021 at 10:35 am
    Hey Brian. Long time since hearing from you. Hope you and Beverly are doing well.
  • al
    September 19, 2021 at 8:15 pm
    We left Freightliner NW on Thursday 5K poorer and with 6 new injectors. No improvement in smoke. After 400 miles we’re back in FL NW parking lot to be first in Monday morning. During the trip I removed the ugly fix and smoke immediately lessened. Still some but not nearly as bad. Several months ago we had a 147 code (VNT blades not responding). FL NW reminded me of this since it was the only code active or inactive. The tech who originally read the code opined it could be a failing EGR valve. FL NW disagreed. Ugly fix remains uninstalled for now but power loss and lower oil pressure were immediately apparent with removal. Will negotiate for new EGR valve without labor. Will advise. Comments welcome.
    September 19, 2021 at 8:33 pm
    Hi Roger & Micki
    We’re doing just fine. We sure miss the old gang. Hopefully we’ve got one more trip east still in us.
    Cheers
    September 20, 2021 at 8:00 am
    Keep us posted on your progress Brian. I’ll bet the green machine is still making smoke, but not white.
