  • Turn signal Retarder connection to Steering column
    Posted by Archived on June 28, 2021 at 11:33 am
    The mount for the turn signal/retarder is loose no matter how tight I turn the nuts holding the collar to the steering column. When I use the turn signal or retarder lever the entire unit pivots.
    Is this a common issue, any fix ideas?
    Dick replied 5 years, 4 months ago 2 Members · 2 Replies
    June 28, 2021 at 12:03 pm
    Very common on my bus. I had to ask my mechanic to fix it twice. I believe there is a tiny set screw missing. Had they not solved it – I was going to just put some 2-sided tape between the column and the ring. It is a real pain when it happens.
    June 28, 2021 at 12:58 pm
    Good to know. Thanks!
    Yes, it’s a drag, as it takes two hands to use either the turn signal or the retarder.
