  • Turn Signal light upgrade
    Posted by AL on December 23, 2013 at 9:18 pm
    If you turn on either turn signal each side has 3 (Marathon) or 5 (Liberty) light bar with plastic lenses. manufactured by
    Grote Lighting Corp.
    On my Marathon the turn signal lights (3) are on top .
    The bottom light is clearence/marker DOT approved
    Grote 2 bulb LED is installed in both locations part # 47073.
    The upgrade is for turn signal replacement with a Grote # 47163 a 6 bulb LED.
    I did this change today buying 1 # 47163.
    Old 47073 with 2 LED
    New 47163 with 6 LED
    The 6 bulb LED is DOT approved and is the same base mount, screw holes, wiring plug in.
    6 LED bulbs make noticeable attention change to be seen in the day time. Simply put all you need is a screw driver to change over super bright 6 bulb LED.
    New 6 bulb LED
    old 2 bulb LED
    new 6 bulb LED uses same plug in.
    New Grote 47163 lense cost retail $ 41.56 each with your Prevost Community NAPA Card cost is $20.73 each.
    The day time brightness was really noticeable. As probably 90% of our travel is during the day this was an in-expensive safety up grade.
    Grote customer service confirmed the voltage and amps are the same. There is no worry confusing any on board processor. in some late model buses.
    Jerry replied 12 years, 10 months ago 15 Members · 23 Replies
  • 23 Replies
    December 23, 2013 at 9:40 pm
    Excellent upgrade and information.
    December 23, 2013 at 9:46 pm
    Not only that I’m impressedwith the discount.
  • Rick & Denise
    December 23, 2013 at 11:02 pm
    Al, your just a boatload of info. Nice upgrade and good info. Price is right too.
    How they treating you over at the park?
    Sid will be home on the 28th and we’ll all get together.
    Later
    bv
  • Rick & Denise
    December 24, 2013 at 3:50 am
    If the other drivers can’t see the big bus maybe the can at least see the bright lights. Nice upgrade.
    Tom and Gray I think Al is trying to show you up… What do have for us next. Rick
    December 24, 2013 at 5:19 am
    I do not know the history of this light or when Prevost started using it, but as a result of talking to Al I found my coach had the 6 LED lights in all positions, both clearance and turn signal on the driver’s side, but the front two rows were the 2 LED lights.
    The difference in how visible you are is considerable. With the 2 LED lights you can see them easily if you are looking straight on at the light, but the lighting becomes much less visible as you move closer to the coach and are looking more along the side of the coach. The 6 LED lights however are clearly visible as Al points out in any position within a 180 degree arc. I always thought I had good lighting because even during the brightest of days I could see my lights on the driver’s side in the mirror. The ones that are only 2 LEDs on the passenger side are not visible to me because of how the mirror is set on that side and those are going to be replaced.
    It would be almost impossible for a passing car to not see you signal to make a lane change with the 6 LED lights. Good catch Al.
    If you have the (presumably older) 2 LED lights replacing them with the 6 LED lights is going to make your intention to change lanes very visible, even in the sunshine.
  • Alvie
    December 24, 2013 at 7:56 am
    This light change is actually a Prevost recommended upgrade.
    I purchased mine direct from Prevost-Nashville @ $24.55 each, and installed them, as mentioned, with minimal tools, back in September.
    Huge improvement and highly recommended for both esthetics and safety!
    December 24, 2013 at 8:04 am
    Rick,
    He’s
    a tough act to follow, but when I explained my Liberty came stock
    with 5 LED lights on each side for the turn signals and his Marathon
    only had 3, all I could hear was crickets!
    Last
    I heard from him, he was on his way to Napa to buy a Sawzall that
    would cut stainless and a big roll of chrome duct tape, he must make
    amends….
    December 24, 2013 at 10:05 am
    When I talked to Truk4u on the land line at first really believed he had his nose into the Christmas punch a little early. Then I realized he’s telling me that Liberty has 5 lights on each side.
    No wonder those Liberty’s cost so much.
    It was Truk4u cargo light post that planted the seed to research upgrades in side marker / turn signal LED…thanks Tom
    Anyone interested tin changing all the side lights including red here is the part number .
    Grote RED 47162
    Thanks everyone , I appreciate your comments
    December 24, 2013 at 10:16 am
    Alvie, I think Prevost has been treating the 2 LED and 6 LED lights as interchangeable according to a post by Jerry on POG.
    It is interesting that both sites had this topic at the same time, but I think Al hit a home run with his research, including showing how we can save some money per light via NAPA. Jerry thanks to Al your problem is solved.
    December 24, 2013 at 10:26 am
    Al,
    I didn’t thank you for all the research you did, so thanks for all the work, we all know where the credit belongs!
  • Michael
    December 24, 2013 at 11:20 am
    Those look great. Any upgrade to LED on my XL?
    Yes, this picture was taken today in 13 sunny degrees.
    DKO
  • Dean
    December 24, 2013 at 11:33 am
    I’ve wanted to do this for some time,but, of course, my vintage coach is 24 vdc
    December 24, 2013 at 11:37 am
    On the lense face does it say, Grote ?
    If yes, what are the 4 numbers near that name ?
    Rodger, Grote also list 24 volt lenses in same design.
    Same question…..Is it Grote lense ?
  • Bryan
    December 24, 2013 at 2:03 pm
    I replaced the faded lenses on my incandescent lights a year ago (’99 XLV) which updated the look of the bus considerably. If I remember correctly the 2 bulbs in each light were hard wired. I did not see a connector outside the bus skin. I guess one would have to solder in the new LED lights. Doable but no plug and play. Did anyone upgrade the old incandescent lights?
    December 24, 2013 at 2:43 pm
    Great Info Al,
    That’s exactly what I was talking about on other site. They must have just come out with those, compared to both I had bought before.
    Being an Ole trucker, I LIKE “chicken lights”
    And thanks again AL!
