Truck Lube Places—Sigh
Took the coach in for the annual oil change and lube. Also had them change the differential fluid. It needed it. All went well until I paid and it was time to leave. The engine would die and not restart. Lost prime. They refilled the filters and I cranked and cranked with some time to let the starter cool off. The refilled the filters and then I cranked some more. Paralleled the house batteries. Could not get the engine to run. Finally they wanted to use ether, I said NO WAY!
They had no way to prime the system externally. As a last resort I suggested to put a little bit of air pressure in the tanks to help prime. Fuel started to pour out of the top of the secondary fuel filter. Turns out they installed an incorrect filter; gaskets were not quite matching introducing air. Once they got the correct filter installed, the engine started and all was well. I don’t think I’ll go there again.
Guess what happend when I opened the fuel fill cap at the truck stop…..
