  • transmission swap
    Posted by petar on August 11, 2012 at 10:01 pm
    has anyone swaped out the manual trany for a automatic like in my bus(87 lamirage xl with a 6v92)
    i have my local prevost rep working on the type of trany i would use but he is on holidays.
    thanks and i hope you can help. i would preffer a mechanical auto over a electric auto
    thanks petar
    Bob replied 14 years, 3 months ago 6 Members · 6 Replies
  • Dan
    August 13, 2012 at 6:40 am
    You’ll most likely will need to use an Allison HT 740 (4 speed) or maybe HT 750CR (5 speed). Do you know which differential ratio you have??
    Ken
    August 18, 2012 at 9:23 pm
    i dont know my ratio off hand but it must be on a tag some where on my diff. i will look this weekend. prevost recomended a b500. they also gave me a ridiculous qoute. 450000 that must include the drive to the plant ha ha ha
    i will look into that tranny. thanks petar
    August 18, 2012 at 9:35 pm
    There is a used B-500 trans for sale on e-bay. Wreck take-out. $3500
    Allison can dyno that trans so you know its good before install. Or you could use above as a core and get a rebuilt for about $7500-$12000
  • David
    August 20, 2012 at 6:45 am
    We may be able to figure out which Diff ratio you have by
    your speed and RPM, most likely your transmission has a 1:1 ratio in
    5th. What is your top speed at 2100 or your speed at any RPM in 5th gear?
    Your ratio probably is 3:73, it could be 3:5 something or 3:36. None of
    these ratios will work very well with a 6 speed world transmission, it will
    never go into 6th and maybe even 5th depending on the ratio you have. If you
    want the world transmission you’ll need something like a 4:5 diff ratio to
    utilize all 6 gears.
    Ken
  • JIM
    August 21, 2012 at 4:52 pm
    I waited awhile to reply. First this is your first conversion. If you swap it is allot of of work and $$$. you will probably drop fuel milage as much as 15%(1 mpg) . So is time to do math. Might just be time to build and enjoy! Look foward to in future going to a four stroke with a 50% increase in fuel milage and a automatic in the future. I’m looking foward to at least 7mpg (hope for better) comapred to my old 5mpg with the 2 stroke automatic. New set up. 60 series 10sp eaton autoshift 4:56 rear gears. Bob
    August 25, 2012 at 6:49 am
    thanks for all the input. i have decided to keep my 5 speed for now and finish the rest of the conversion. went for a drive and dont mind the shifting. and i am getting pretty good mileage for now.(2500 km on a tank)
    i have enuff to do without adding to the list
    thanks petar
