  • Transmission Seal Leak
    Posted by DON on January 5, 2019 at 9:35 pm
    Took my bus for a pleasure cruise yesterday. When I got home, I noticed some wet spots on the back of the bus. So I looked underneath, and could see that the Allison B500 transmission output shaft seal is starting to leak. I’m a DIYer.
    Does anybody have the part#?
    Has anybody changed it themselves?
    Dick replied 7 years, 10 months ago 6 Members · 9 Replies
  • 9 Replies
    January 6, 2019 at 9:52 am
    Not just the seal, most likely the drive shaft yoke will have a groove in it and will need to be replaced, also the nut on out put shaft has a hellacious tight torque spec. Prevost will have the parts and were competive with allison on price, also had rebuilt yokes. good luck
    Glenn
  • Jimmy
    January 7, 2019 at 9:21 pm
    Bought the seal today at Stewart Stevenson for $71. It’s a National/Allison pt# 29552705. Thing is HUGE! It’s bigger than my flip phone.
    This seal leaking is a common problem with old Allisons that were manufactured before synthetic ATFs came to market. I run Allison approved High Capacity filters and Mobil Delvac 1 synthetic TES-295 ATF. The old original seal is not totally compatible with TES-295 synthetic ATFs, this according to ex Allison Fluid Engineer Tom Johnson, now with JG Lubricant Services JG Lube
  • terry
    January 8, 2019 at 10:41 am
    I have a slight weep on the output seal too. Please keep us posted on repair progress/procedure. Does not look like a walk in the park.
    January 12, 2019 at 8:00 pm
    I changed my Allison B500 output shaft seal today. Easy job. Six bolts. The yoke was fine. It slides off the shaft with 1 hammer tap after the 2 small 15 mm bolts are removed. The 4 bolts that hold the u-joint straps are 1/2″ 12 point.
    Lubed everything on the rear of the bus while I was at it.
    Old bad seal # 29515691. New seal # 29552705.
    I plan to change the fluid and filters again soon. I don’t know what was in it when I bought it. I changed it 4.5 yrs and 18k miles ago with Mobil Delvac 1 synthetic, an Allison approved TES-295 fluid, and Allison high capacity filters. I’ll take a sample an send it in for analysis and see if it needs changing first.
    January 12, 2019 at 10:28 pm
    Thanks for the pictures, Don. That looks actually quite doable. Did you have to drain the transmission fluid? I’d guess not because the sump is so much lower.
    January 13, 2019 at 7:27 am
    Excellent post. Free dues for a year!
    January 13, 2019 at 8:02 am
    There is zero fluid loss when the seal is removed.
    January 13, 2019 at 9:32 am
    Way to go Don! you da man, I’m also a DIYer and next oil change i will change seal, did you replace those 2 little seals?
    January 13, 2019 at 6:15 pm
    No, u dah man
    I had no idea they were there. if I ever see those 2 bolts heads wet, I’ll know the fix.
