Trace Inverter remote issue
My house batteries are shot and it will be a little bit before I will be replacing them. I have disconnected all but one battery from the bank to the coach effectiivly resulting in a large capacitor making the coach function. I know that poor batteries can wreck havic on the sytem but I’m stuck with this for the present.
While plugged in to 50amps an RV park things were functoning rather normally but now I am plugged into power at a friends place using 2 regular extension cords going into an adapter box which the 50amp cord plugs into. A cheater box. I already know it’s preferable to have two heavier guage cords but these are just the regular home owner size.
Problem: One of the remotes and inverters is holding steady but the other one keeps toggling between a blinking light on “AC IN Good” and a steady green ligth on “Float”. When it’s blinking on “AC IN Good” the yellow “Inverting” light comes on. It probably toggles between these two lights once every 5 mintues.
I tried turning the battery charging settings on that remote in question all the way down to like 1 amp maximum float thinking maybe it would relive the duty on that inverter/charger but no change. I am only running one A/C in the bedroom and I have the water heater off. The A/C whether, it’s on or off doesn’t seem to be affecting it which makes sense to me, but when the toaster or the microwave is used it aggrevates the problem right away, which also makes sense assuming it was a charge load issue on that particular charger.
My breaker box inside has seperate breakers for the inverter and charger half’s of each 2500 watter inverter. Today I turned the Charger breaker to that inverter OFF inside the coach but to my surprise the inverter still went into “Float” mode. Hmm. I don’t get that at all.
I flip flopped the two small electrical cords going into the cheater box to allow for a difference in the lenght of the cords (a 50′ on one vs a 100′ on the othe) but the problem stayed on the same remote instead of migrating with the flipped cords.
I already know a couple of you that know me are not going to be surprised that I’m having elecrical issues and your going to let me have it for my past shannigans possibly leading to some issue so go ahead……………let me have it. I am trying to be a good boy from now on yet here I am working with this set up and I”m going to be here for a while so that is why I am posting for so I can trouble shoot more. I know I probably need to get larger size cords to beging with. Also, when I run the generator the issue is not there as you would suspect.
Why does the remote stay in “Float” when I turn the charger off at the breaker ? That is the case with both chargers and remotes not just the one.
Thanks in advance for any input.
