  • Trace Inverter Odd Reading
    Posted by David on August 21, 2020 at 4:12 pm
    Hello,
    I have a 1998 XL Featherlight Vantare. Ever since I purchased the coach in August of 2018 when the generator is on and both Trace inverters 4024 units are in bulk and when I am monitoring the AMP load ( on the inverter LCD Screens). They will add a third number to the amp load.
    Example: If the load is 20 amps, it will show 200 amps and back to 20…back and forth.
    This only happens when on generator and in bulk mode. It never happens in float.
    I thought at first it might be a clinch from generator, but I just replaced my Pro Tech 17.5 gen set head along with a new voltage meter. It still does the same thing.
    Everything works just fine and not noticeable in the function of the coach / inverters.
    Has any one seen this happen? Thoughts?
    David Thomas
    1998 Featherlight XL
    Dick replied 6 years, 3 months ago 2 Members · 1 Reply
  • 1 Reply
    August 22, 2020 at 8:11 am
    Give Inverter Services a call, they can help you out with the display problem.
