Trace inverter acting up
Hi Ya’ll,
Our bus has the Trace inverters, today, the #1 inverter threw an “overcurrent” error (though, we didn’t have much on, just the usual stuff) all AC’s were off.
I turned it on and off and now if I try to use shore power the AC1 flashes, but it won’t switch to AC and it inverts for a bit and then throws “overcurrent” again.
it seems to work ok if I run the generator…. at least it did for a few hours
The #2 inverter seems to be working correctly
I tired turning to power on/off to the inverter… the 24vDC and it worked once, but then failed again in a short while.
nothing has really changed and we just got back from Marathon in Texas. The bus has been sitting for a few days and this started.
I’ll call around in the AM but thought I’d ask the PC and see if anyone had some ideas..
