  • TPS Voltage Low
    Posted by Liam on June 25, 2013 at 12:56 pm
    Somehow stupidly I must have turned-off my chassis battery charger and juice was just too low to start the engine. I let it charge a few hours and was able to easily start the engine.
    I have no idea if this is coincidence or not, but I am getting a “TPS Voltage Low” error on the DDEC control head. The cable is firmly connected at the pedal.
    Two questions:
    1. Any ideas?
    2. Does this mean I won’t be able to drive to the service center because the engine won’t know I am stepping on the gas?
    Roger replied 13 years, 3 months ago 6 Members · 11 Replies
  • 11 Replies
    June 25, 2013 at 1:12 pm
    Liam,
    If it is working OK you will be able to rev the engine when you step on the pedal.
    If not it is not working. I can’t help other than that.
    June 25, 2013 at 2:07 pm
    That is what I figured. Just hoping this was something common and easy to fix or there was a “work around”.
    The service book diagnostic wants me to check for “other codes” but I don’t have a reader so that is useless. I will have to see how many of the steps I can do without one.
    Now I know why “fly by wire” is so scary!
    June 25, 2013 at 2:36 pm
    I assume you’ve tried a reboot by turning the ‘ignition’ off.
    June 25, 2013 at 5:37 pm
    Just grabbed my flashlight and headed down to diagnose. I pulled the pedal back and cycled the sensor through its range several times and blammo, the check engine light went out and Miss DDEC now happy. My guess is inside is an old fashioned rheostat that just got dirty. Bummer if that went out on the road!!
    June 25, 2013 at 7:00 pm
    Liam,
    You can flash the codes using the check engine light, but I don’t remember the procedure. I’ve done it, but the ole memory isn’t what it used to be.
    June 25, 2013 at 8:20 pm
    I read that in the manual but it didnt make sense how a light on the dash could do that. I will have to dig through the manual and learn.
  • Liam
    June 25, 2013 at 8:34 pm
    Mine was doing the same thing. I looked into my SilverLeaf glass dash alarm history and discovered the alarm was raised more times than I had noticed. The rheostat is far more expensive than I would have ever guessed. Buy it from Prevost and you can save nearly $100 over what I paid at the Detroit facility in Vegas.
    June 25, 2013 at 8:52 pm
    Thanks everyone.
  • Roger
    July 21, 2013 at 9:30 pm
    Just replaced the TPS today. Thought it would be an easy swap but no such luck. New sensor has a different connector so it came with a new cable. Instead of just swapping sensors, I had to remove the whole pedal assay. Worst part was crawling into the bumper compartment to find the connection on the other end which was tie-wrapped in a hard to reach area.
    Did they use child labor to wire this bus??
    Better than a day at the office though.
    July 22, 2013 at 6:16 am
    I think was a test for you Liam:)
  • Fred
    July 22, 2013 at 5:37 pm
    No Joke, I know three guys that worked at the Prevost conversion facility in Oklahoma. I can not recall the converter but it was later ran by Featherlite. They declare up and down that there was a very short man that worked there and did a lot of work in the bays.
    DKO
