  • towing Cadillac Escalade EXT 2007
    Posted by Matthew on March 31, 2014 at 2:59 pm
    I found very little info online or from Cadillac about towing an Escalade Behind our 2005 Prevost. The Escalade is fulltime AWD truck. I installed a Remco pump kit with Blue OX base plates and towbar. The base plates were very easy to install and the pump kit was about a 4 hour job. I hole needs to be drilled into the oil pan and a fitting installed. The directions were simple and easy to follow. Prevost has many spare wires that run from front to the rear so installing the controler in the cockpit was easy as well. Just left friday and went nonstop to Orlando with no problem. We did have to install a battery disconnect on the Caddie to keep the battery from going dead while the key position was in the acc detent. Wouldn’t hesitate to do it again! FYI
    Matt
    Midwest-studios
    2005 Experiential Coach
    Matthew replied 12 years, 7 months ago 1 Member · 0 Replies
