  • Toll Window Repair – XLII
    Posted by needtocamp on July 15, 2016 at 10:01 am
    How to install a toll window lift
    Several weeks ago, a thread was started about replacing the toll and or the co-pilot window lift motors.
    I had posted a comment about not being able to use the toll window any more because I was afraid of not being able to close it anymore.
    Jon had posted about having found the least expensive motor at Rock Auto. I went ahead and ordered 2 motors so as to have a spare for when it may be needed, if the other motor stopsworking.
    Here are the order details:
    Manufacturer: Cardone Select
    Part No. A1 82-144
    Category: Window Motor
    The price with shipping was about $52.00 for 2
    Now, for the funpart. The installation. I am always hesitant when it comes to all things mechanical. I do have 2 left hands. But, ahead I went …
    You start by removing the inside panels.
    Once you have removed the panels and the noise/water barrier, you will be looking at the assembly (above) and you will have to drill out 3 rivets, which Jon referenced in his posts. The rivets will be very obvious.
    You will also have to loosen and remove 2 nuts in order to pull the assembly off of the wall. Again, this will be obvious.
    This is the old motor. It comes out very easily once you have drilled out the rivets and removed the 2 nuts.
    The above photo shows the assembly with the motor removed.
    The photo here below shows the newly installed motor and you can see clearly, where the old rivets were drilled out and new rivets were inserted.
    The result … PERFECT. What a difference a new motor can make!
    My time from start to finish was about 1.5 hours. Anybody who is used to do mechanical work can do this in less time.
    I am glad that I did this. Now, the toll window works like it used to work.
    Amazing what a $25 part can do!
    Cheers,
    Ronald
    Ronald & Gabi Hiemann
    ‘Olivia Las Vegas’
    2007 Teschner Prevost XLII
    needtocamp replied 10 years, 3 months ago 1 Member · 0 Replies
