Tom, would you mind posting a picture of the Pressure Pro mounted in your bus. It looks like the best system available but the shape of my dash gives me trouble when trying to imagine where to mount it. I’m hoping if I see one installed it would give me perspective. Thanks
Not a good picture, but it’s mounted on the verticle post with velcro. Since everything is black, it blends in well.
This is the repeater in the bedroom. You need this to assure no loss of signal to your toad. Some have hidden this in a cabinet, never tried that, but if the look bugs you, may want to try it hiding it.
George,
On my last bus, I could not find a cosmetically acceptable location for the Pressure Pro display. I bought the Silverleaf VMS330 which allow the option to overlay the pressure data on the rear view monitor. It also give you all the DDEC info as well. The system was elegant and bulletproof. I would certainly do it again.
I don’t think it would be difficult to find an acceptable location for any device such as a pressure pro in the driver’s area. I am sure the dash mounted position would be made to work, but it could also be mounted below the dash, or on the wall to the left of the driver. I had a CB mounted on the cabinet to the driver’s right one time so even that location could be considered.
John also had a very good idea if someone uses a Silverleaf or has changed the CC dash to a Silverleaf dash.
Thanks to all for the information and to Tom for the pictures. I never considered a vertical mount for the Pressure Pro. John thanks for the Silverleaf suggestion. The prior owner had installed a Silverleaf dash and I will check out the upgrade costs.
