  • Tire pressure loss
    Posted by Joe on May 21, 2015 at 9:15 pm
    Something strange happened!
    I usually check my tire pressures each day before leaving a campsite. When we left Dallas all pressures were fine. I failed to check the tires before leaving San Diego on Saturday morning since it was raining. Tuesday morning when I checked the pressures in San Francisco, the left inner drive tire had ZERO pressure. I pumped it up to 90 pounds and checked it every 12 hours since and drove to Yreka CA today checking the pressure twice along the way with no apparent loss of air.
    So, what happened for that tire to lose all the air, AND when did it happen? It doesn’t seem possible I could have driven 500 miles with it totally flat. I suspect someone let the air out in San Diego, but if so how did I drive to San Francisco with all the weight on one drive tire and a flat inner? Is that at all possible? (The valve cap was on properly.)
    Any thoughts?
    Archived replied 11 years, 5 months ago 6 Members · 8 Replies
  • 8 Replies
    May 21, 2015 at 10:50 pm
    First off Grizz I don’t know how much pressure you run in your tires and I don’t usually even get in tire discussions because I have different thoughts on that but if your tire was low you could of popped the bead.
    I have seen things happen on trucks that sometimes you can’t explain and just consider yourself lucky.
    You need to contact Truk and get a tire pressure monitor, you only get away with a story like this once.
    Later
    bv
    May 22, 2015 at 6:37 am
    Every time tire pressures are checked the Schrader valve is opened, and then has to reseal.
    If it did not seat itself properly when the pressure was last checked the slow leak could have caused the pressure loss. Any other slow leak such as the bear or a puncture is not going to repair itself so if it held after refilling it was likely the Schrader valve.
    At this point you might give some serious thought to 2 new tires. Unless the leak happened while the coach was sitting in the RV park, you probably drove on the inner tire with pressure much lower than the required pressure. But as the tire pressure on that tire went down, the outer tire was carrying more and more weight, and as the weight it carried increased it likely exceeded the pressure required in the tire for that weight.
    May 22, 2015 at 8:09 am
    I strongly agree with Jon. Two tires to be replaced.
    Running with a flat on a multi axle trailer or on a dual wheel subjects the “good” tire to overloading, almost guaranteeing a catostrophic failure of the “good” tire.
    I have reached this conclusion as a result of three personal experiences. BTW, if anyone finds a Florida license plate attached to a portion of blue steel fender near I-75, Exit 13 in Georgia, it’s mine.
    May 22, 2015 at 8:20 am
    Shrader valve or extension comes to mind if you have no puncture in the tire from road debris, especially those extensions.
    Here’s a possibility… You removed the valve stem cap, the extension wasn’t tight and turned loose just a tiny bit. Now the extension is leaking at the valve stem, but you can’t hear it. You put the valve cap back on, but again, it didn’t tighted the extension. You lost all your air, but when you aired it up and put the valve cap back on the extension was just tight enough not to leak. Tighten your extension and see if it’s loose. Or better yet, throw those extensions in the trash. If you aren’t using extensions, the Shrader comes to mind.
    According to Michelin, that tire is junk.
    PS – Pressure Pro would have prevented the run flat with the low pressure alarm before the tire lost enough air to consider it damaged and needing replacement.
    May 22, 2015 at 9:39 am
    I ran into the same issues with the extensions. Pulled those off and replaced them with solid stems.
    The extension is just one more point that can fail and leak. Doesn’t matter how tight the valve cap is installed, if the extension isnt seated properly, or it’s seal is bad, you can have a leak.
    May 22, 2015 at 10:21 am
    As Jon points out, checking tire pressure can cause small valve leaks. I have started using soapy water when checking tire pressure. I almost always find one leak. Getting a good blast of air through the valve fixes it.
    May 22, 2015 at 1:11 pm
    I never mentioned valve stem extensions because I know the folks on this forum are too well informed to use those.
  • jack
    May 22, 2015 at 6:22 pm
    Thanks for the insight! We are in Coburg for some minor repairs next week, so I’ll have them do an inspection and replace as needed.
