  • Tire cleaning/Dressing
    Posted by Jerry on December 21, 2017 at 10:58 am
    I’ve always tried to stay away from Tire dressings, even though some of them make the tires look better at times, and then some make a mess and may be harmful to the tires, or are hard to wash and clean once you use it. I try to just keep them clean.
    After installing 4 new 365’s, which seem to have a chalky film on them, maybe a protective coating of some kind, I cannot get it off. I have tried soap and water, degreaser, all sorts of tire cleaner, scrubbing with a brush, and nothing seems to get it off!
    What are you guys using?
    Hard to tell in the picture, but they look way worse in person!!!
    glen replied 8 years, 10 months ago 10 Members · 13 Replies
  • 13 Replies
  • Jim
    December 21, 2017 at 11:51 am
    The only products that I know are safe on tires and protect from UV damage are “303 Areospace Protectant” and Aero Cosmetics’ “Rubber Care”.
    Wash Wax All from Aero Cosmetics is used by the Air Force One Squadron along with a number of cleaning supplies designed for aircraft use such as Rubber Care.
    Soap and water and a good scrubbing are my only hints at cleaning the surface of a tire.
  • Tom
    December 21, 2017 at 12:07 pm
    I, too, use 303 Protectant on the tires. It’s not too shiny but makes the tires look clean. As I’m washing the coach, I’ll clean the tires with soap and water. Once dry, I’ll spray the 303 on.
    Safe travels,
  • Larry
    December 21, 2017 at 1:40 pm
    thanks, I hadn’t thought about 303. I was told Armour all Extreme is water based, but not sure.
    December 21, 2017 at 6:28 pm
    Ditto ‘303’.
    December 21, 2017 at 7:41 pm
    Years ago a old truck driver said he used bleach on his tires, to help traction in wet weather, also said they looked new all the time. I have used on my pickup couple times.
    Jim Brown
  • Rocky And Tonya
    December 21, 2017 at 7:54 pm
    Jim Brown posted …”Years ago a old truck driver said”……
    was his name Bernie ?
    December 21, 2017 at 9:54 pm
    Al, he said “OLD” truck driver, Bernie is just ornery.
  • Roscoeapproved
    December 21, 2017 at 10:17 pm
    Jerry,
    After I purchased my bus I had it washed in Spearfish, SD and told the guy, do not put any of that crap on my new tires. Should have stuck around, came back and one of his nit wits did what I asked him not to. It took almost 2 years for crap to come off and made the tires look blotchy. I use 303. Maybe someone put some of that garbage on your tires.
    Jeff and Lindsay
    91 Marathon XL
    December 23, 2017 at 7:44 am
    Tom, these are brand new tires just put on, I wasn’t going to put anything on them, but they look so splotchy, I got to do something, I’ll do the 303.
    It feels like a protective coating of some kind, the tires have been in storage since late ’16, but I had to have them. No newer date codes could be found. Reminds me of Cosmoline that used to come on new cars a long time ago, a white chalky/sticky substance.
  • Deleted User
    Deleted User
    December 23, 2017 at 9:14 am
    What you describe is probably mold release compound. It is sprayed in the mold so the rubber will release.
  • victor
    December 23, 2017 at 10:21 am
    I would suggest everyone go to page 83 on the link below because that is the Michelin suggestions regarding tires and tire protectants.
    http://www.michelintruck.com/assets/pdf/Truck_Tire_Service_Manual_2011.pdf
    December 23, 2017 at 5:07 pm
    the info is on page 78
    Happy Day!!!
  • Roscoeapproved
    December 23, 2017 at 5:14 pm
    One of these days I need to learn to read.
    Jeff and Lindsay
    91 Marathon XL
