  • Tecma toilet question
    Posted by Scott on April 4, 2016 at 9:32 am
    I have a Tecma macerating toilet in our coach. The black tank is empty and has been back flushed…..
    The grinder is struggling – working hard, with just water.
    It most likely has had a large amount of paper, one ply, but just can’t throw it off the blades. It still pumps water, I’m a bit concerned but it has flushed some solids but we are not sending down any paper. I’ve tried flushing the hottest water I could get from the tap in the coach, then Dawn Dish soap, and hot water overnight. Then about 6 hours with some ZEP Enzyme build up remover. And HOT water These have not made any difference.
    Any suggestions? Now I’m in the process of putting in some Blue Thetford tank treatment direct to the blades. It’s a challenge because the door to the blades will not allow a wand to go into it, might break the door. It only opens just for a moment while pumping out. It would be nice if the motor had a reverse switch built in somewhere accessible. Not to my knowledge of this coach.
    Thanks,
    if if someone had time to call.
    Scott
    248-760-3082
    John replied 10 years, 7 months ago 12 Members · 18 Replies
  • 18 Replies
    April 4, 2016 at 11:12 am
    Don’t have a Tecma but it might be time to pull grinder and clean or replace. Doesn’t sound like flushing gonna do it. Glad I’ve got a straight drop to black tank on my electric Microphor.
  • Thomson
    April 4, 2016 at 7:15 pm
    I called Scott all good now
  • needtocamp
    April 5, 2016 at 9:15 am
    Peter, Can or Scott let us all know what the issue was and how it was resolved?
    April 5, 2016 at 7:11 pm
    I think Scott should answer , but do not put to much paper down there if you are dropping the kids off at the pool one flush will do ,but if you are dropping off the Brady Bunch two flushes will do, I have never had that problem in 11 years with one
    April 5, 2016 at 10:01 pm
    Ha ha! Thanks Peter! No Brady Bunch here!
  • Dan
    April 5, 2016 at 11:33 pm
    For the benefit of other Tecma Owners. I will elaborate on what I think Peter is saying.
    You can clog them with too much paper. Just ask my 13 year old daughter. We had just left Marathon in Eugene and she told Me dad it won’t flush. Leon walked me through a few things on the phone and when that didn’t work back to Marathon we did. Took it all apart and yep just a massive amount of paper… I now know how to take it apart and fix it if it ever happens again. This was about 6 months into our 14 month trip and I told my daughter if it happens again she gets to clean it .. Problem solved
    April 6, 2016 at 11:15 am
    Note to Tecma owners,,
    Keep bathroom rug handy and scoot your heiney around on rug like a puppy dog. Solves the problem of toliet paper and Tecma’s.
    April 6, 2016 at 1:59 pm
    Problem solved:
    Skip all that stuff about adding enzymes, blue toilet chemical – slippery soaps and/or hot water, etc etc.
    First shut off all water pumps and water supplying the toilet, just turn off all shore water. Drain water from your sink to release the pressure to the toilet. You want to control all water flow to the toilet with your hose. Then bring a clean hose in through the closest window.
    I Just used a garden hose with a plastic quick squeeze hand nozzle, that you can quickly turn off and on. As the unit flushes and the grinder comes on use a lot of pressure from your hose nozzle, right as the grind begins. Squirt during the first grind, then pause and wait for the second grind- hit the water nozzle again. Quit after grinding stops, leave just enough water to not flood out the bowl. My model has a fairly small door not a door style that you can even see. The nozzle needs to be just where the water exits the bowl. You can get a good angle on it and adjust the direction as needed. I had no idea what direction to shoot but it worked after about six flush cycles you could hear the grinder wasn’t bound up with paper any more.
    If you you have a toilet model with a 3″ visible door be SURE to not put anything inside against where the door closes and seals between the door and the bowl. It will undoubtedly break the toilet door mechanism….
    Thanks for the interest and calls.
    Scott
    April 6, 2016 at 8:07 pm
    Glens,
    That’s it, you are the man….
    While at Autofest I saw Jon doing that heiny scoot in the grass and yaking about an itchy butt, now it all makes sense to me.
    April 7, 2016 at 6:32 am
    I never signed up for this much abuse. I’ve stayed out of this because you guys clearly don’t know shidt.
    April 7, 2016 at 8:37 am
    Just exactly how much did you sign up for ? Geo.
  • Per
    April 7, 2016 at 9:30 am
    I checked the box where it said “No Abuse”, but obviously the folks running that portion of the web site also run the “Do Not Call List”.
    I am also developing some real concerns about the members of this site given the extreme interest in things not normally discussed by polite people. Look back at topics like this one and the two tank thread and how much interest there is in such things.
    April 7, 2016 at 11:21 am
    Old people get bored easily. Geo.
    April 7, 2016 at 12:52 pm
    As procative as you are about changing parts based on time, ie Norgren valves, air bags, etc, I cannot believe you are not changing your Abuse filters more freqeuntly.
    ROFL
    April 7, 2016 at 1:32 pm
    I can see that Mikee is going to fit in just fine. Geo.
