tank sentry
Posted by Archived on May 24, 2015 at 1:42 pmOur tank monitor is given zero indication, I reset the control box in water bay but the monitor keeps going to zero. Any info would be great. Thanks in advance.
2003 Liberty h345 sorry Al
Archived replied 11 years, 5 months ago 10 Members · 14 Replies -
I don’t want to be a smart *** but……if we can get some bus infomation someone can help with your question.
Check to make sure the clear hose coming out of the tank sentry box in the plumbing bay has a good connection, as it works off air pressure and an air leak will give a low reading. If that doesn’t fix it then recalibrate your tank sentry. Mine was doing the same thing a few months ago. Took it to a Converter here in FL and they told me the entire system needed to be replaced for a couple thousand. I wasn’t buying that and recalibrated it myself. Ten minutes later all was well.
Hopefully Pete and Re-Pete won’t catch it. You could count on minimum double dues increase next year.
It could be the monitor board also,I replaced two monitor boards that where not working all good now , last year
l -
BBB do you have the calibration procedure for the tank sentry? Please email them to me.
My email address is dukeflyer2507@att.net.
Pete Liberty Coach replaced the boxes for me in Feb. I think it is the clear plastic tube is loose. I will work on it tomorrow when I get the calibration procedure.
dukeflyer01,
Does your display look similar to these? I don’t have the instructions with me. They’re in the coach, which isn’t with me right now either. I might be with the coach later this week and I’ll copy the instructions for you when I get back if someone else doesn’t have the for you by then.
BBQ
I can wait when you have time please email it to me. My display is the same. Thanks -
call headhunter or go on web page it’s on there very easy just need to know what panels you have
1-954-581-6996 headhunter. procedure depends on weather they are little round LEDs or the rectangle ones different for each one, what do you have
Great. Going off memory on the back of the display there are two trim pots. One red and one green. The red one adjusts the reading for a full tank and the green one adjusts the empty reading. Since yours is reading empty the 1st step is to have a full tank. Then go to your plumbing bay and press and hold, for about 10 seconds, the little button on the bottom of the corresponding sentry box. Then go back inside and turn the red trim pot clockwise until all the red LED’s are illuminated. Continue a half turn once all LED’s are illuminated. I find a tiny flathead screwdriver that you can get from CVS or Walgreens used to tighten the screw for eyeglasses works best.
Again, this is just going off memory from several months back. But when I get to the coach I’ll copy and send you the printed instructions.
Note: As Peter has pointed out there are different versions and the shape of the LED’s is a quick way to differentiate them. All my LED’s are round, unlike the picture I posted earlier.
Hish,
Look on the back of the box the hose hooks to, I think the calibration instructions are written on the box.
Please post the utube link and tips. Sou D’s like something I need to know as I also have tank sentry units ( round LEDs)
Hish
Replace the o rings before you get too far. I JUST HAD THE SAME EXACT PROBLEM WITH OUR Liberty. After 12years the o rings are dried out. You can get the replacements at Home depot.
See if this helps.
You do not have to empty and refill a tank to calibrate the Headhunter sentry.
Make a tube plugged at one end that is the height of the tank, and use that to simulate your holding tank for purposes of calibration. The system is just looking for head pressure.
https://www.youtube.com/watch?
v=qMdsqjf-7qI
