  • Tank Drain Valves
    Posted by Art on January 7, 2024 at 10:34 am
    Replaced all the Tank drain valves about 5 or 6 years ago and I have a couple leaking! Is there a better drain valve than this one??
    Archived replied 2 years, 10 months ago 5 Members · 5 Replies
  • Alex
    January 7, 2024 at 9:12 pm
    Hello Art – Agree… seems they do not last very long.
    I have replaced them twice in just under five years of Prevost ownership. Since the first time, I only replace those on the wet, primary, secondary, and aux tanks; and, have PLUGGED all ping tanks.
    With a properly operating and routinely serviced engine driven compressor AIR FILTER DRYER, water will never make it to a ping tank.
    January 8, 2024 at 8:51 am
    X 2 on Jeff’s comment.
    I plugged the ping tanks
    Chuck
  • Towson
    January 8, 2024 at 10:07 am
    I ordered a couple of cable type pull drains to try, I was tempted to just install 1/4 brass ball valves??
  • Jeff
    January 8, 2024 at 10:24 am
    Have always wondered why Prevost does not install upon their air tanks “automatic moisture ejectors” (my verbiage)
    Both Spartan and Freightliner use them
    https://n0c357rmy1njbuit2friqwu.blob.core.windows.net/documents/xfTl94x$I0EBhB_SD-03-2501_US_008.pdf
    January 12, 2024 at 12:42 pm
    I’ve used this type for years as replacements and have never had one fail. Do a search for pipe thread petcock. You may need several different size pipe threads.
