  • Tag Hub & Brake Preventative MX
    Posted by DON on December 18, 2022 at 8:04 pm
    Went to suck out and replenish the gear oil in the tag axle wet hubs and noticed a dirty black film on everything in the hub. (see 1st pic)
    So I:
    Removed rt. rear tire/wheel, washed it inside & out
    Disassembled/removed tag axle right rear hub, rotor, etc. Bearings were good.
    Removed hub seal & installed new Scotseal SKF# 35066 (Prevost# 610870) with seal installation tool.
    Cleaned & lubed slide pins, caliper bushings, and installed new o-rings on pins
    Re-assembled everything and set bearing end play at 0.002”
    Lubed caliper
    Installed new wet hub caps, Road King 343-4024 (Stemco is same part#, or Prevost# 611252)
    With the axle level refilled hub w/Amsoil SVG 75w-90. It takes a few minutes for the the gear oil to flow thru out the hub.
    Test drove bus.
    All went good
    I’ll to do the same to the left tag and the right steer soon. I did the left steer last April when the gear oil hub cap started leaking between the metal & plastic.
    Mike, 92 Country Coach replied 3 years, 11 months ago 2 Members · 1 Reply
  • 1 Reply
  • Mike, 92 Country Coach
    December 19, 2022 at 10:36 am
    Wish we were neighbors! Would love to help & learn!
