  • Tag axle shock mount
    Posted by Archived on March 11, 2015 at 9:58 pm
    Does anyone have a clue if the upper shock mount on a 1999 XLV tag axle is a screw in stud. Marathon Grand Prairie was installing new shocks and found the curbside tag axle upper shock mount was snaped off. To me it looks like a screw in stud, but they said it would have to go to Prevost Ft. Worth and have the whole upper mount cut off and a new one put on. This sounds a bit excessive and dumb to me, but would like to hear from someone who has had their shocks off themselves. Any help is appreciated.
    Dean replied 11 years, 8 months ago 4 Members · 3 Replies
  • Dean
    March 11, 2015 at 11:03 pm
    Sorry to read about this problem. I would not be concerned about the repair at all.
    In the hands of a truck frame shop and notice the two words… “Truck Frame” this is and easy repair for an
    experienced frame repair mechinac, no big deal.
    What part of the country are you in ?
  • Alan
    March 12, 2015 at 9:21 am
    Coincidently, today I have the right side tag wheel off to replace brake caliper slide pins. So I just went out and looked at the shock mounts. It looks like there is a stud, threaded on both ends. One end screws into the chassis, then the shock slides on that stud, then a washer and nut screw onto the outside of the stud holding the shock in place. All I can see behind the shock that makes me think it is a stud is a hex seated up against the frame. Logic: why would there be a hex there if not to put a wrench on? And I didn’t see a weld bead there either. It is easy access once the wheel is removed. Good luck.
    According to my vin number, my model is a 1994 chassis.
    March 12, 2015 at 10:43 am
    screw in torque 450lb Bob
