  • Tachometer – Identification/Replacement
    Posted by Ronald on October 2, 2020 at 6:23 pm
    Alright,
    You will see that I am also following a discussion on Speedometers, but this is a separate issue that I am having. Previous post I had for speedometer was good accuracy from 1 to 40 MPH, then it starts bouncing. My digital gauge that I use tells me that when I am doing 65 MPH the VDO is showing between 50 MPH and 55 MPH. Talked with Prevost and was advised to order a speed sensor.
    This is the latest observation I have from weekend travel last week that is related to the tachometer. Gauge goes to 500 RPM, sits there for a few minutes, drops to zero. Turn on fast idle and it goes back up to 500 RPM and then drops to zero. After a while the gauge just sits a zero.
    Flip on switches like lights, or fog lamps, or four way flashers, and I see a brief increase, and then back to zero.
    Pulled the dash cover. Found this information, but can find zero from a web search:
    Dixson, Inc.
    Grand Junction, CO USA
    Tachometer
    Model: 530C0-47636
    24 Volt.
    Also, according the wiring diagram there should be Red, White, Brown, Yellow. As far as an tell I have Red, White, Brown, and Green. Used an amp meter and checked Red and Brown and got a reading of 24.7.
    Any assistance that can be provided will be appreciated.
    Marshall replied 5 years, 2 months ago 3 Members · 2 Replies
    October 3, 2020 at 7:51 am
    Check for a loose or bad ground behind the dash.
  • Marshall
    July 9, 2021 at 9:25 am
    Following this thread as my tach has never worked in the 3 years I have owned my coach. Grounds seem okay in the dash and everything else works fine.
    The tachometer needle does swing fully around and back during pre-flight with the computer when you turn the key on but never, and has never, registered an RPM reading.
    Since it is properly swinging at pre-start test, would one think it could be on the engine bay end?
    I haven’t been able to find much on troubleshooting the tach not registering without some other symptoms attached to the problem, so I’m not really sure where to start digging.
